[LDPartEditor] First Alpha Version News (until 2014-09-19) - Printable Version
+--- Thread: [LDPartEditor] First Alpha Version News (until 2014-09-19) (/thread-7056.html)
[LDPartEditor] Line and Face Selection I - Nils Schmidt - 2014-05-12
[Image: face_selection2.png]
[Image: line_selection.png]
Another visualisation of selected faces:
[Image: face_selection.png]
Re: [LDPartEditor] Anaglyph Car - Michael Heidemann - 2014-05-17
This looks indeed also very good Smile
Re: [LDPartEditor] First Alpha Version News - Stephan Meisinger - 2014-05-18
I would like to test the latest version. But according to SourceForge only the initial version is available?!
In the SVN-Repository is no building instructions. But according to the files commited I need eclipse. Do you ever considered adding a Maven-POM for building?
[LDPartEditor] Transform Control / Manipulators - Nils Schmidt - 2014-05-20
[Image: manipulator.png]
Re: [LDPartEditor] Self-made Build? - Nils Schmidt - 2014-05-21
Yes, I thought about it, but I am not going to change my project setup.
I will post detailed building instructions in the near future.
For now, I can only provide my ANT buildfile (for linux).
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<project default="create_run_jar" name="Create Runnable Jar for Project LDPartEditor_linux">
    <!--this file was created by Eclipse Runnable JAR Export Wizard-->
    <!--ANT 1.7 is required                                        -->
    <target name="create_run_jar">
        <jar destfile="/home/nils/workspace/LDPartEditor/LDPartEditor_linux_x86/LDPartEditor.jar" filesetmanifest="mergewithoutmain">
            <manifest>
                <attribute name="Main-Class" value="org.nschmidt.ldparteditor.main.LDPartEditor"/>
                <!-- Modified Classpath -->
                <attribute name="Class-Path" value=". plugin/"/>
            </manifest>
            <fileset dir="/home/nils/workspace/LDPartEditor_linux/bin"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/LDPartEditor_linux/lib/lwjgl_util.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/LDPartEditor_linux/lib/lwjgl.jar"/>
            <fileset dir="/home/nils/workspace/org.eclipse.swt_linux"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/org.eclipse.swt_linux/swt.jar"/>
            <fileset dir="/home/nils/workspace/org.eclipse.jface/bin"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/jface/org.eclipse.core.commands_3.6.0.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/jface/org.eclipse.equinox.common_3.6.0.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/jface/org.eclipse.jface_3.5.0.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/jface/org.eclipse.osgi_3.6.0.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/jface/org.eclipse.ui.workbench_3.1.0.jar"/>
            <fileset dir="/home/nils/workspace/com.sun.tools/bin"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/runtime_compiler/tools.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/LDPartEditor_linux/swt-grouplayout.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/workspace/LDPartEditor_linux/swing2swt.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/org.eclipse.core.databinding_1.4.1.v20130515-1857.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/org.eclipse.core.databinding.beans_1.2.200.v20130515-1857.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/org.eclipse.core.databinding.observable_1.4.1.v20130515-1857.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/org.eclipse.core.databinding.property_1.4.200.v20130515-1857.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/org.eclipse.jface.databinding_1.6.200.v20130515-1857.jar"/>
            <zipfileset excludes="META-INF/*.SF" src="/home/nils/eclipse/plugins/com.ibm.icu_50.1.1.v201304230130.jar"/>
        </jar>
    </target>
</project>
[LDPartEditor] Constructive Solid Geometry (CSG) - *UPDATED 2014-06 -24* - Nils Schmidt - 2014-06-02
LDPartEditor will also support CSG.
Here are screenshots from the first implementation draft:
A "union" with a cube and a sphere:
https://lh3.googleusercontent.com/-vo20SayMBkM/U_Jk2Z3PZII/AAAAAAAAAF4/xErAkN-2QSo/w582-h734-no/csg_v2.png
A cube "minus" a sphere and its intersection with another sphere:
https://lh6.googleusercontent.com/-YZk9rVM_Xgs/U_Jk28yJ5wI/AAAAAAAAAGA/DhInvHZdocM/w582-h733-no/csg_v2_2.png
RESULTS of the final implementation Smile
[Image: csg_complex_example.png]
[Image: csg_final_implementation.png]
Re: [LDPartEditor] Constructive Solid Geometry (CSG) - Philippe Hurbain - 2014-06-02
Wow! You're going to make Intersector obsolete... and I thank you for that Wink
Re: [LDPartEditor] Constructive Solid Geometry (CSG) - Magnus Forsberg - 2014-06-02
Nils, the king of teasers...
[LDPartEditor] CSG - A more complex example with DAT source code - Nils Schmidt - 2014-06-25
0 // CSG commands can be used in subfiles, too
0 // The identifiers are non-global and bound to the file / subfile
0 // It is possible to inline CSG commands from subfiles
0 // SYNTAX 1 0 !LPE [CSG FORM] [ID] [COLOUR] [MATRIX]
0 !LPE CSG_CUBOID    a  4 0 0 0 1 0 0 0 1 0 0 0 1
0 !LPE CSG_ELLIPSOID b  1 0 0 0 1.35 0 0 0 1.35 0 0 0 1.35
0 !LPE CSG_CYLINDER  c  2 0 -1 0 .7 0 0 0 2 0 0 0 .7
0 !LPE CSG_CYLINDER  d  2 -1 0 0 0 2 0 .7 0 0 0 0 .7
0 !LPE CSG_CYLINDER  e  2 0 0 -1 .7 0 0 0 0 .7 0 2 0
0 // SYNTAX 2 0 !LPE [CSG FUNCTION] [ID] [ID2] [ID3]
0 !LPE CSG_UNION c d d
0 !LPE CSG_UNION d e d
0 !LPE CSG_INTERSECTION a b f
0 !LPE CSG_DIFFERENCE f d f
0 // SYNTAX 3 0 !LPE CSG_COMPILE [ID]
0 // The COMPILE command displays the CSG volume on the screen
0 // Inlining the following line will generate triangles of the CSG volume
0 !LPE CSG_COMPILE f
0 // E.g.
0 // Inlined: !LPE CSG_COMPILE f
3 4 -10 1.5752766 7.3133416 -10 1.5752766 8.313231 -10 3.3930404 7.6749177
3 4 -10 1.5752766 7.3133416 -10 -2.6084895 6.481139 -10 -2.6084895 7.9504156
3 4 -10 1.5752766 7.3133416 -10 -2.6084895 7.9504156 -10 9.094947E-16 8.866396
edit: Adjusted transformation matrix syntax to LDraw standard
edit2: changed !LD_PART_EDITOR meta command to !LPE
[LDPartEditor] Hide Selection / Show All - Nils Schmidt - 2014-06-28
Similar to the behaviour of MLCAD, it is now possible to hide and show selected objects.
[Image: ghost_show.png]
[Image: ghost_hide.png]
