Lego Space Collections - Printable Version
+--- Thread: Lego Space Collections (/thread-6998.html)
Lego Space Collections - Nathan S - 2012-11-24
Please add any Lego Space models you have put in LDraw.
Mtron 1478 - Nathan S - 2012-11-24
[unnamed] 1478
Mtron 6811 - Nathan S - 2012-11-24
Pulsar Charger 6811
Mtron 6833 - Nathan S - 2012-11-24
Beacon Tracer 6833
Mtron 6862 - Nathan S - 2012-11-24
Secret Space Voyager 6862
Mtron 6877 - Nathan S - 2012-11-24
Vector Detector 6877
Mtron 6896 - Nathan S - 2012-11-24
Celestial Forager 6896
Mtron 6923 - Nathan S - 2012-11-24
Particle Ionizer 6923
Mtron 6956 - Nathan S - 2012-11-24
Stellar Recon Voyager 6956
Mtron 6989 - Nathan S - 2012-11-24
Mega Core Magnetizer 6989
Re: Lego Space Collections - Willy Tschager - 2012-11-24
Mine can be found in the LDraw All-In-One Installer and yours would be added immediately to it if they were OMR compliant.
Re: Lego Space Collections - Nathan S - 2012-11-25
You want to fill me in on being OMR compliant
Re: Lego Space Collections - Willy Tschager - 2012-11-25
Your files have to respect a certain structure - we are not talking about order or naming, but how the header of your files reads. The specs can be found here:
Official Model Repository (OMR) Specification Version 1.0.2
Check also the models in the AIOI for reference. Further there is a fine tool which will verify that everything is okay:
MPDCenter
Once they are OMR compliant just re-post them here and I'll copy them to the AIOI. BTW I use:
LEGO Collector - 2. Edition
for the MPD naming
6780 - Light & Sound XT Starship - Ignacio Fernandez Galvan - 2012-12-02
OK, this is my first model. Flexible parts created with LSynth. I've uploaded (or am about to do it) updates for the bricks with lights to the part tracker. I'm trying to comply with the OMR format too.
Cockpit and Probe submodels are detachable.
EDIT: Updated and fixed placement.
EDIT: Updated L&S parts.
[Image: 6780.png]
Re: 6780 - Light & Sound XT Starship - Willy Tschager - 2012-12-03
Many thanks - added to the AIOI. There were some "~Moved to" I had to replace. I also replaced the unofficial 73664.dat with the old official 4771.dat. It doesn't make much sense adding an unofficial update if there is an official file available.
Re: 6780 - Light & Sound XT Starship - Ignacio Fernandez Galvan - 2012-12-03
Fine, I should have checked the "~Moved to" parts first. As for the unofficial files, I guess it comes down to which is updated first Smile But you are right, I should have changed the reference to the still-official part.
Re: 6780 - Light & Sound XT Starship - Ignacio Fernandez Galvan - 2012-12-05
I've updated the model.
6827 - Strata Scooter - Ignacio Fernandez Galvan - 2012-12-05
A small Classic Space model.
[Image: 6827.png]
6875 - Hovercraft - Ignacio Fernandez Galvan - 2012-12-05
A small Futuron model.
[Image: 6875.png]
6891 - Gamma-V Laser Craft - Ignacio Fernandez Galvan - 2012-12-05
A Classic Space Model. Cockpit is detachable. Includes a minifig-sized robot.
[Image: 6891.png]
EDIT: Updated, an accessory was missing.
6933 - Spectral Starguider - Ignacio Fernandez Galvan - 2012-12-05
A Blacktron II model. Cockpit and aircraft are detachable from the vehicle and can be attached together (included as a submodel, not part of the main one, I hope that's OK).
Unlike other models I've uploaded, I don't own this one. It uses the still-unofficial part 2515 (the wheels).
[Image: 6933.png]
6951 - Robot Command Center - Ignacio Fernandez Galvan - 2012-12-05
A Classic Space model, with three minifigs, two smaller vehicles and a rocket, all three detachable. The arms and claws can be moved too (if you dare).
[Image: 6951.png]
Re: 6951 - Robot Command Center - Willy Tschager - 2012-12-06
All files do not have a valid .mpd name. See:
http://www.ldraw.org/article/593.html#base_file_naming
I further suggest to rotate the 6951 at 90 degree (clockwise) to be in sync with your correct assumption:
http://forums.ldraw.org/showthread.php?tid=7142&pid=7142#pid7142
Re: 6933 - Spectral Starguider - Jude Parrill - 2012-12-07
Dang it, I just finished this model the other day!
Edit: Well, I'm not quite sure if his model is OMR-ready, but mine is!
Re: 6951 - Robot Command Center - Ignacio Fernandez Galvan - 2012-12-07
Willy Tschager Wrote:All files do not have a valid .mpd name. See:
Do you mean that they should be named "6951 - Robot Command Center - Rover", "6951 - Robot Command Center - Antenna", etc.? In that case I should rename the files in other models too...
Ah, no... you mean the actual filename, not the names defined in "0 FILE" lines. I'll fix those too.
Quote:I further suggest to rotate the 6951 at 90 degree (clockwise) to be in sync with your correct assumption:
I can't make sure of it in this now (I'm at a work computer), but I believe the orientation is "correct", I just rotated the view for the picture...
Re: 6933 - Spectral Starguider - Ignacio Fernandez Galvan - 2012-12-07
I tried to comply with the OMR too... I'll check the differences when I can Smile
OK, so you've defined the different submodels in a "logical" way, to allow easier rotation/translation when needed (especially for movement or animations), whereas I just followed the instructions. Your way is more practical indeed, but is it preferred?
I may also note that at least my editor (LDCad) shows some very small overlap in the cockpit's top cover (I had to rotate it 43.9 degrees instead of 44, if I'm not mistaken), and some gaps between the minifigs' hands and arms (you could use the minifig I posted in http://forums.ldraw.org/showthread.php?tid=7102&pid=7102#pid7102).
Re: 6951 - Robot Command Center - Willy Tschager - 2012-12-07
Everything is fine now - copied to AIOI!
Re: 6933 - Spectral Starguider - Willy Tschager - 2012-12-07
A quick check with MPDCenter says:
Check for: 6933 - Spectral Starguider.mpd
True - Mirrored parts free.
False - All files have correct License.
True - All Name entries are like filename.
True - Is MPD filename OMR conform.
False - All filenames in the MPD are OMR conform.
True - ~Moved to parts free.
False - Unresolved references free.
Error in: 6933 - mm.ldr Filename without setnumber does not match file description.
Error in: 6933 - mm.ldr Filename not OMR conform because of the above error(s).
basically your scheme:
0 6933 Spectral Starguider
0 Name: 6933 - mm.ldr
is not correct. This has to be either:
0 mm
or
0 Spectral Starguider
0 Name: 6933 - Spectral Starguider.ldr
Unofficial part 2515.dat not referenced correctly. Uses physical color part 302026.dat.
Re: 6933 - Spectral Starguider - Michael Heidemann - 2012-12-09
You use the file 2515.dat, but that is not official at present. So you have to import that file into the MPD and also the referenced subfiles.
Re: 6933 - Spectral Starguider - Ignacio Fernandez Galvan - 2012-12-10
I suggest we keep this model on hold at least until 2515.dat is finished, and better until it is official.
Do you have anything to say about which way to define the submodels (matching the instructions, or making it easier to rotate and translate the different parts of the model) is preferred?
Re: 6933 - Spectral Starguider - Michael Heidemann - 2012-12-10
Please have a look in the spec. There you can read:
should enable any instructions generated to be as close to the official instructions as possible.
I think this answers your question.
Re: 6891 - Gamma-V Laser Craft - Ignacio Fernandez Galvan - 2012-12-16
An accessory was missing (black arm on the left side clip). Model updated.
Re: 6780 - Light & Sound XT Starship - Ignacio Fernandez Galvan - 2013-01-02
New update, using the new L&S bricks.
Re: 6780 - Light & Sound XT Starship - Nathan S - 2013-01-24
I re-downloaded the AIOI, and made sure that it included the "official models," but I can't find them after install. Do you know what file they would have been placed in?
Re: 6780 - Light & Sound XT Starship - Michael Heidemann - 2013-01-24
On my system they are placed in a folder called "Ldraw" in my documents folder.
Exactly right, thanks. I had been looking under program files.
Re: 6780 - Light & Sound XT Starship - Ignacio Fernandez Galvan - 2013-02-24
Here is the same model, but with flexible hoses modeled in LDCad, rather than with LSynth.
1499 - Twin Starfire - Willy Tschager - 2018-01-08
.mpd   1499 - Twin Starfire.mpd (Size: 5.22 KB / Downloads: 5) (OMR compliant)
Known errors: None
Renderer done with LDCad POV export (Hint! IT TOOK ME AN HOUR TO FIND THE RIGHT COMMAND: View -> Editing views -> Export -> Pov Ray view export).
I do not like the grey skydome; tried to set "emission srgb  1" but it bleaches the colors too much. Nonetheless the output is stunning! Chapeau!
1557 - Space Scooter - Willy Tschager - 2018-01-09
.mpd   1557 - Space Scooter.mpd (Size: 2.56 KB / Downloads: 6) (OMR Compliant)
Errors: none
