WebGL renderer - Printable Version
+--- Thread: WebGL renderer (/thread-6835.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Re: WebGL renderer - Nicola - 2013-08-21
Of course it is, that's why i made it Smile
Re: WebGL renderer - Willy Tschager - 2013-08-30
Question is: Is there a way to use it here on the forums in some ways? For example generating pics of models or parts people just submit as .ldr or .dat and a pic of the content is added to the post?
Re: WebGL renderer - Nicola - 2013-08-30
Yes, that shouldn't be hard. What you need to run it is loading the part library to some folder on the same origin as the page running it. I think Ldraw should already have it avaiable. The rest is standard javascript fiddling (include JS files, add some snippet of code, etc).
Here's a more detailed howto.
You can take a look at the simplest example here.
Rebrickable is also using brigl on their part detail page.
Re: WebGL renderer - Steffen - 2013-08-30
WOW; that would be AWESOME...
EVEN the parts tracker could show the PARTS this way...
imagine a 3D object there, interacting with your mouse...
Re: WebGL renderer - Rolf Osterthun - 2013-09-12
Hey Nicola,
indeed, the LDraw site should have the complete library online (can somebody confirm that?).
I think the biggest challange is, that your renderer needs the complete library in a special
folder structure (one folder or your suggested subfolder structure).
I have almost no skills in JavaScript, but I had a closer look into your code, tried some
changes and used copy and past to generate the following code snippet (the paths are
hardcoded):
asyncReq: function(partName, callback)
  var purl = "../parts/"+partName;
  purl = purl.replace(/\\/gi,"/");
  this.asyncnum++;
  new Ajax.Request(purl, {
    method:'get',
    onSuccess: (function(transport) {
      var res = transport.responseText;
      this.asyncnum--;
      callback(res);
    }).bind(this),
    onFailure: (function() {
      purl = "../p/"+partName;
        method:'get',
          this.asyncnum--;
          callback(res);
        }).bind(this),
          this.asyncnum--;
          alert( 'Something went wrong loading: '+purl);
        }).bind(this)
    }).bind(this)
Due to my missing knowledge of JavaSkript, I have no idea if my code causes deadlocks or
dead threads or ... whatever. But it seems to work with the standart folder structure: http://www.digital-bricks.de/en/index.php?site=3d&part=3005
I would really like to see your Brigl renderer used at the parts tracker and / or in this forum.
Rolf
Re: WebGL renderer - Orion Pobursky - 2013-09-12
This is in the works. I just want to make sure it "fails gracefully" on unsupported browsers/hardware
Re: WebGL renderer - Steffen - 2013-09-14
YAY! hurray!
Re: WebGL renderer - Orion Pobursky - 2013-09-18
I'm having trouble implementing the viewer.
Everything seems to be working fine. The log messages are displaying but the viewer doesn't appear.
I think this might be a file path issue. I'm using:
var builder = new BRIGL.Builder("parts/",{dontUseSubfolders:true});
What should the library path I pass to the viewer be relative to? The html file containing the viewer code? Absolute for the webserver?
Re: WebGL renderer - Rolf Osterthun - 2013-09-19
Hey Orion,
for the digital-bricks.de website, I use the following line:
var builder = new BRIGL.Builder("../parts/", {dontUseSubfolders:"true"});
I use the relative path from the html file containing the viewer code. When your parts folder and this file are in the same folder you may try "./parts/".
Rolf
Re: WebGL renderer - Orion Pobursky - 2013-09-19
Ok. It was a path and permissions problem with my local server. Hopefully I fixed it and can have this up soon on the forums.
