WebGL renderer - Printable Version
+--- Thread: WebGL renderer (/thread-6835.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
RE: WebGL renderer - Michael Horvath - 2016-08-21
Does anyone know how to write a Windows batch file that sorts the parts library into sub-folders based on the first letter in the file name? The docs say that this should be done for performance reasons. Thanks.
[edit]
Never mind. I was able to move everything manually.
It is weird that your models need to go in the parts directory. I'd rather put them in a "models" directory next to "parts". Could this be changed in the future? Thanks.
[edit]
Here is my first model that I got working:
http://isometricland.net/lego/brigl/ldr_androbot.php
I tried enabling the "dontCenter" option because I want the script to use the model's coordinate system, but this placed the camera directly at the robot's feet. I could not zoom out any further.
RE: WebGL renderer - Michael Horvath - 2016-08-22
Feedback:
1. One problem I noticed is that the viewer doesn't detect when the mouse leaves the display window. As a result, if you are holding a mouse button down when the cursor goes off screen, the viewer still thinks it is pressed when returning to the screen, even though you are likely to have released the button by then.
2. It would be nice to change the background color. I use a gray color normally in LDView.
3. How should we advertise for Brigl? Just link to the github page?
4. I would like to turn studs off to speed up rendering. Overall, performance is not as great as LDView.
5. Large models take a while to load. A better indication of loading using a GIF animation would be good.
6. Moving the scene using the middle mouse button is slow. You have to do it over and over again to make progress.
7. I added a border "border:3px double #888;" to the container, but the display overlaps this border to the bottom and right.
[edit]
This model crashes Chrome for some reason, and results in a black screen in IE.
http://isometricland.net/lego/brigl/ldr_carriagehouse.php
Not sure why. The others work. Lack of memory?
RE: WebGL renderer - Hazen Babcock - 2018-02-19
If you are using the Github version of Brigl and you'd like some help, or you've found a problem, please open an issue on the Github project page. For reasons unclear to me, even though I think I'm subscribed to this thread I never get any e-mail notices about new posts.
best,
-Hazen
RE: WebGL renderer - Orion Pobursky - 2018-02-20
(2018-02-19, 22:59)Hazen Babcock Wrote: If you are using the Github version of Brigl and you'd like some help, or you've found a problem, please open an issue on the Github project page. For reasons unclear to me, even though I think I'm subscribed to this thread I never get any e-mail notices about new posts.
best,
-Hazen
I think I fixed the issue. Not sure.
RE: WebGL renderer - Hazen Babcock - 2018-02-20
best,
-Hazen
Thanks! I'm getting the e-mail notices now.
RE: WebGL renderer - Jaco van der Molen - 2018-02-20
For what it is worth: loading stops at "Loading 3-4ndis.dat" in Firefox.
This one loads fine http://isometricland.net/lego/brigl/ldr_androbot.php
(2018-02-20, 12:01)Jaco van der Molen Wrote: For what it is worth: loading stops at "Loading 3-4ndis.dat" in Firefox.
Sorry, loading of what?
I just checked simple with Firefox 58.0.2 (64-bit) and it loaded correctly.
That simple loads fine with me too.
It is this one that stops loading like stated in this thread:
It is loading many dat files but stops at "Loading 3-4ndis.dat"
RE: WebGL renderer - Hazen Babcock - 2018-02-21
(2018-02-20, 14:22)Jaco van der Molen Wrote:
(2018-02-20, 12:34)Hazen Babcock Wrote: Sorry, loading of what?
There seem to be two problems here. The first is that this model requires two files 'm6666.ldr' and 'm6643.ldr' which are not found on this server. The missing file problem then triggers a call to an error callback function which has a bug, causing an exception and stopping the model loading process. I think the bug is fixed in the current version of BRIGL, but there is not much I can do about the missing files.
RE: WebGL renderer - Michael Horvath - 2018-08-20
best,
-Hazen
FYI
https://github.com/HazenBabcock/brigl/issues/8
I installed the latest GitHub version. My first model loads eventually, but there are dozens of 404 errors in Chrome's Developer Tools.
http://isometricland.net/brigl/ldr_redrockracer.php
If I try a larger model, it does not load properly, and eventually results in my whole website becoming unresponsive for 15 minutes or thereabout.
http://isometricland.net/brigl/ldr_carriagehouse.php
