WebGL renderer - Printable Version
+--- Thread: WebGL renderer (/thread-6835.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Re: WebGL renderer - Michael Horvath - 2014-11-30
I have no control over the file system. I just rent space from a web hosting company.
Re: WebGL renderer - Nathanel Titane - 2014-12-06
Hey there Nicola,
Been playing around with Brigl and must say I love it.
Is there any way to revise or enable LDraw's standard parts directory listing instead of the parsing your JS proposes or the no subdir option (which forces everything into a single directory)?
Thank you.
Re: WebGL renderer - Rolf Osterthun - 2014-12-06
Nathanel Titane Wrote:Is there any way to revise or enable LDraw's standard parts directory listing instead of the parsing your JS proposes or the no subdir option (which forces everything into a single directory)?
Hey Nathanel,
it is some time ago now, but I once wrote this post. I think this is exactly what you are looking for?
Rolf
Hey Rolf, thanks for posting the reply Smile - where would I append the code to enable it? I am litterally |-----| << this close to getting it to work on my blog Smile
brigl does not seem to support the mpd file format...
is there any way to have it parse it properly?
Rolf, I fixed the hardcoding:
asyncReq: function(partName, callback) {
var purl = this.partsUrl + partName;
purl = purl.replace(/\\/gi, "/");
this.asyncnum++;
new Ajax.Request(purl, {
method: 'get',
onSuccess: (function(transport) {
var res = transport.responseText;
this.asyncnum--;
callback(res);
}).bind(this),
onFailure: (function() {
purl = this.partsUrl + /p/ + partName;
method: 'get',
this.asyncnum--;
callback(res);
}).bind(this),
this.asyncnum--;
alert('Something went wrong loading: ' + purl);
}).bind(this)
}).bind(this)
Nicola, any way to add touch event listenenrs to brigl?
Re: WebGL renderer - Nathanel Titane - 2014-12-07
Well, my friends, here is what I've got so far: http://nathaneltitane.blogspot.ca/p/test_6.html
Re: WebGL renderer - Nicola - 2014-12-15
Nathanel Titane Wrote:Hey there Nicola,
Thank you.
Thanks Smile the nosubdir option actually use the standard part directory listing, it is not that it require a single flat directory. Just use the option and plug your library as is, it should work.
Nathanel Titane Wrote:Nicola, any way to add touch event listenenrs to brigl?
Actually that is Threejs stuff. Brigl basically create a Threejs object, and then you can do whatever you want with it. I included the BriglContainer code that will create a very basic Threejs scene, but that's just for convenience.
Brigl already support mouse event, so i guess you need touch events such as from tablets or smartphones?
Let me know if you need more help Smile
Re: WebGL renderer - Hazen Babcock - 2016-02-23
Hello Nicola,
I've been hacking on this a bit as I was interested in something that would work on a tablet. I've added touch event handling (one finger to rotate, two to zoom / translate). I've also updated it to use three.js r74, tried to improve the centering and some other minor changes. If you are interested, my work is here:
https://github.com/HazenBabcock/brigl
Is your brigl project on bitbucket still active? Can I send you a patch with these changes?
best,
-Hazen
