Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . (/thread-6630.html) |
Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . - Willy Tschager - 2012-11-08 The 75174p01c01.dat - Animal Dragon Oriental w. Chr.Gold Head and Tr.Red Wings (Comp.) makes use of 30130.dat an alias of 6133.dat - Animal Dragon Wing, causing an error when the Alias library isn't installed. This should be corrected in the next release. 75174c01.dat - Animal Dragon with Red Wings (Complete) is fine. w. Re: Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . - Magnus Forsberg - 2012-11-08 IMO, this is not an error. 30130 is the correct number for the dragon wing in this assembly, since it is made of transparent plastic. It is stated inside that file: Quote:0 // Alias of 6133 There are many of these combinations. Like: 50746 "Slope Brick 31 1x1x0.667", correct number for transparent colours 54200 "Slope Brick 1x1x0.667" correct number for opaque colours Quote:0 !HELP Part 50746 is the counterpart of 54200. Visually, the two parts seem You have to keep the different aliases apart. Sometimes an alias is transparent/opaque, and sometimes it's a new partnumber. Re: Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . - Steffen - 2012-11-08 leaving away the alias files never occured as a good idea to me. sometimes 2 numbers have the same right of existence, and people might use the one or the other in their models. thus, by installing something on your harddisk which is "ldraw minus alias files", you're disabling yourself from loading other people's models correctly. Re: Part-Assembly in the CA-Library uses Alias instead of a CA-Ppart . - Michael Heidemann - 2012-11-10 Like Steffen already wrote the Alias files belong directly to our library. Otherwise we would for example need a tool to extract those alias parts from the official OMR files. The alias parts should never be split from the library. |
