[Complete] 3010pb011b Brick 1 x 4 with Black 'L 17.5 TON' and 'T 10.6 TON' Pattern - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: [Complete] 3010pb011b Brick 1 x 4 with Black 'L 17.5 TON' and 'T 10.6 TON' Pattern (/thread-6606.html) |
3010pb011b Brick 1 x 4 with Black 'L 17.5 TON' and 'T 10.6 TON' Pattern - Michael Heidemann - 2012-11-05 I need for an old set the following part: http://www.bricklink.com/catalogItemPic.asp?P=3010pb011b Anybody that can do pattern is invited ![]() Thanks for your help in advance. Re: 3010pb011b Brick 1 x 4 with Black 'L 17.5 TON' and 'T 10.6 TON' Pattern - Philippe Hurbain - 2012-11-09 Done... Font is not perfect (I used arial narrow bold with txt2dat and tuned some characters with LDraw Pattern Creator) but "good enough" I think! http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/3010pt1.dat Re: 3010pb011b Brick 1 x 4 with Black 'L 17.5 TON' and 'T 10.6 TON' Pattern - Michael Heidemann - 2012-11-09 Thanks a lot! You are - as always - awaresome quick
