DATHeader 3.0.9.0 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: DATHeader 3.0.9.0 (/thread-66.html) |
DATHeader 3.0.9.0 - Michael Heidemann - 2011-07-24 I just release version 3.0.9.0 of DATHeader. Please leave all comments for this version as response to this topic. Have fun. Download from http://mikeheide2.kilu.de cu mikeheide Re: DATHeader 3.0.9.0 - Michael Heidemann - 2011-11-12 Sort order for History entries should change, so that brackets {} will be sorted in front of [] brackets. Re: DATHeader 3.0.9.0 - Chris Dee - 2011-11-13 !HISTORY sequence should be strictly by date. In the entries prior to the 2008-01 release it's quite possible for a {} quoted RealName to come after a [] quoted UserName. See official 2345p44.dat for a valid example of this. Chris Re: DATHeader 3.0.9.0 - Daniel Goerner - 2012-03-31 I don't know what happened, but I can't open DATHeader anymore. I reinstalled all things LDRaw to a new directory (on the very same HDD), also DATHeader. And now, when I try to open DATHeader it says "write protected folder: The folder for the lists can not be written to. Can not use it. I use instead: C:\....\Documents." After I click OK the program crashes. I use Windows 7 64bit, it worked before, now it doesn't work anymore. I tried to change authorisations, ownership of the folder and whatnot. Different program versions, different hdds, everywhere the same thing... [EDIT] I reinstalled Java, now the program doesn't crash anymore, but the error message comes as soon as I click any button. The program knows all the old directories, also my username etc. Maybe there's a registry entry I have to delete, so the program starts fresh. But where in the registry is this program stored? Re: DATHeader 3.0.9.0 - Daniel Goerner - 2012-04-01 Now I installed a one month old backup of my system, before I installed DATHeader. Now it works. I think it's a registry thing. Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-04-01 Datheader does not use the registry. Instead in your documents folder there is a file called datheaderini.xml. In that file all pathes are stored and also your preferences and your name. Just delete that file and fill in the necessary pathes again in DATheader. I am sorry for the inconviences DATHeader caused to you. Re: DATHeader 3.0.9.0 - Daniel Goerner - 2012-04-01 Let me say that in German: "Na toll!" I take that with humor. It was frustrating, yes, but now it works, and for the future I know what causes the problems. So, nevermind. Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-04-01 In case you think about reinstalling your system in the future, just because of one of my apps, please send me an email. I do not look into this forum every day, but I check my emails every day (normally ![]() But I hope you will continue using my apps and enjoy the benefit they give to you. If you have any idea for improving - please do not hesitate to contact me! Re: DATHeader 3.0.9.0 - Daniel Goerner - 2012-04-01 Thanks Michael. Here's another problem (?) with DATHeader. I don't know what it means, but I get an error message most of the time DATHeader checks the body: "Error in LDraw_IsErrorLines in modLdraw at check no. 8 Der Index war außerhalb des Arraybereichs." Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-05-06 Sorry for my late reply. Please send the file where this error occure to my email address. So I can check here what is going wrong. Thanks for your patience. Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-05-06 Did you use the latest version? Version 3.0.9.1 (Released 2011-11-12) Re: DATHeader 3.0.9.0 - Steffen - 2012-05-06 ugh, where can that be downloaded? page http://www.ldraw.org/Downloads-req-viewdownloaddetails-lid-71.html still shows ancient version 1.1.8, and http://mikeheide2.kilu.de/index.php?page=datheader only lists 3.0.9.0, not 3.0.9.1... BTW, I also find the relict (?) pages http://home.arcor.de/mikeheide/db86.html http://datheader.mikeheide.kilu.de http://www.softpedia.com/get/Others/Miscellaneous/DATHeader.shtml http://code.google.com/p/datheader/downloads/list quite confusing... Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-05-12 Different versions are my fault ![]() Current best place is http://mikeheide2.kilu.de I try to mention at all places that http://mikeheide2.kilu.de is the current place to look for DATHeader. I thought I would have released on 2011-11-12 version 3.0.9.1, but you are right - I did not. Blame on me ![]() This will be fixed soon, as I have sorted out what other changes I made between then an now and how they work right now. Regarding the error message mentioned by Daniel, I remember this error, but not the real reason. It is definitely the 'Check for BFC INVERTNEXT followed by a linetype1' that failed. No real problem but need to be fixed or is already fixed. If I would have the file where this error occur I could test here! Re: DATHeader 3.0.9.0 - Daniel Goerner - 2012-05-12 I don't remember wich file it was, but as soon as I get the error again, I'll send it to you. Re: DATHeader 3.0.9.0 - Michael Heidemann - 2012-05-12 I have just uploaded the current version 3.0.9.1 to http://mikeheide2.kilu.de That error should be fixed if I remember correctly. Before you install the new version, just try a file with BFC NOCERTIFY if the same error occur. If yes, then it should be fixed in the new version. Thanks for your feedback. Re: DATHeader 3.0.9.0 - Steffen - 2012-05-12 (let's collect the feedback at http://forums.ldraw.org/showthread.php?tid=4851&pid=4851#pid4851 centrally, please, not here) |
