Are meta-commands case-sensitive? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Are meta-commands case-sensitive? (/thread-6521.html) |
Are meta-commands case-sensitive? - Alex Taylor - 2012-10-29 Almost all official and unofficial meta-commands that I've seen are written in all-caps (the exceptions being 'Name' and 'Author', presumably for historical reasons). I can't find anything which specifies that this is mandatory when defining new metas, so does anyone know: - is it in fact mandatory, or just convention? - should parsers be case-sensitive or case-insensitive when dealing with metas? (As an aside, 'meta' is not an acronym, so should not be written as 'META' as it seems to be throughout the specs...) Re: Are meta-commands case-sensitive? - Travis Cobbs - 2012-10-29 The official LDraw 1.0.2 spec document specifies that meta-commands must begin with a ! and must be in all caps. The text for this is in something of an odd location: the Meta Command sub-section under the Line Type 0 sub-section of the Line Types section. It is not in the main Meta Commands section of the document. Re: Are meta-commands case-sensitive? - Alex Taylor - 2012-10-29 That would be why I didn't see it then :-) Thanks! I take it then that the recommendation is that parsers should not treat (eg) '0 bfc invertnext' and '0 BFC INVERTNEXT' as the same thing? Re: Are meta-commands case-sensitive? - Tim Gould - 2012-10-29 Does the LSC want to take a quick vote to put it in the list document? eg. Change Quote:The following is a list of META commands that have been formally adopted into the LDraw.org File Format and links to the applicable specifications. Note that all new official META commands will have a "!" as the prefix characterto Quote:The following is a list of META commands that have been formally adopted into the LDraw.org File Format and links to the applicable specifications. Note that all new official META commands will have a "!" as the prefix character and must be in capital letters. Re: Are meta-commands case-sensitive? - Orion Pobursky - 2012-10-30 I'm not sure we really need to vote since this change is semantic and doesn't actually change any requirements. Re: Are meta-commands case-sensitive? - Tim Gould - 2012-10-30 Do you want to make the change? I think it would be better as you are actually on the LSC. I know it's pedantic but since we have a long list of rules and this falls under the spirit of them I'd prefer it. Re: Are meta-commands case-sensitive? - Orion Pobursky - 2012-10-30 No prob. I'll do it after I have dinner. Re: Are meta-commands case-sensitive? - Orion Pobursky - 2012-11-02 This is now done. I made some minor navigational tweaks to the File Format and Official Meta Command docs. |
