Technic Part Request (Anchor) - Printable Version
+--- Thread: Technic Part Request (Anchor) (/thread-5680.html)
Technic Part Request (Anchor) - Oh-Seong KWON - 2012-07-28
This is an anchor for technic part request for me or anyone who loves technic.
[Done] 10197 Technic, Axle and Pin Connector Hub with 2 Axles - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=10197
[Image: 10197.jpg]
Thanks for reading Smile
(((Undone))) 95292c01 Technic, Shock Absorber 9.5L, Complete Assembly (Extra Hard Spring) - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=95292c01
[Image: 95292c01.jpg]
Thank you Smile
[Done] 99012 Technic Rotor Blade Small with Axle and Pin Connector End - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=99012
[Image: 99012.jpg]
Thank you Smile
[Done] 99013pb01 Technic Rotor Blade Large with 3L Liftarm Thick and Black Rubber Tip - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=99013pb01
[Image: 99013pb01.jpg]
Thank you Smile
[Done] 111b Technic, Axle and Pin Connector 3 x 3 with Axle - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=111b
[Image: 111b.jpg]
Thank you Smile
[Done] 56908 Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pinholes - Oh-Seong KWON - 2012-07-28
http://www.bricklink.com/catalogItem.asp?P=56908
[Image: 56908.jpg]
Thank you Smile
Re: 111b Technic, Axle and Pin Connector 3 x 3 with Axle - Philippe Hurbain - 2012-07-30
This one does exist already: http://www.ldraw.org/library/official/parts/58177.dat
Re: 10197 Technic, Axle and Pin Connector Hub with 2 Axles - Rolf Osterthun - 2012-07-30
Hey,
it should be done: 10197.dat
Rolf
Thanks alot :) - Oh-Seong KWON - 2012-07-31
Hi
Thanks for your concern Smile
Thanks again
Kwon
Thanks for information.
I didn't know that 111b and 58177 are the same part.
Thanks again
Kwon
Re: Thanks alot :) - Rolf Osterthun - 2012-07-31
Your welcome,
please watch out for the part at the parts tracker. Its orientation has already changed Smile...
Rolf
Re: 99012 - why need this part - Oh-Seong KWON - 2012-08-01
I need this part to complete 9396 that has been almost done.
[Image: a0111809_5018883443055.png]
Re: 99013pb01 - why need this part - Oh-Seong KWON - 2012-08-01
[Image: a0111809_5018883400941.png]
[Done] 99499c01 Electric motor - Oh-Seong KWON - 2012-08-31
[Image: 99499c01.jpg]
http://www.bricklink.com/catalogItem.asp?P=bb571c01
---> http://www.bricklink.com/catalogItem.asp?P=99499c01 (Changed part number)
Electric, Motor 9V Power Functions L with Dark Bluish Gray Bottom
Please, make this part as soon as possible.
Thanks for reading. Smile
[Done] 99498c01 Electric motor - Oh-Seong KWON - 2012-08-31
[Image: 99498c01.jpg]
http://www.bricklink.com/catalogItem.asp?P=bb572c01
---> http://www.bricklink.com/catalogItem.asp?P=99498c01 (Changed part number)
99498c01 Electric, Motor 9V Power Functions Servo with Dark Bluish Gray Bottom
(((Undone))) 8448 Sticker - Oh-Seong KWON - 2012-08-31
http://www.bricklink.com/catalogItemPic.asp?P=8448stk01
[Image: 8448stk01.gif]
Able man in the world!! convert this sticker to LDraw parts, please.
Re: bb572c01 Electric motor - Philippe Hurbain - 2012-08-31
I plan to do the PFS large and Servo motors, but these complex shapes takes time Wink
Re: bb572c01 Electric motor - Oh-Seong KWON - 2012-09-01
Great! I am happy to hear good news!
I can wait!
Thank for your work Wink
(((Undone))) 8880 Sticker - Oh-Seong KWON - 2012-09-03
http://www.bricklink.com/catalogItemPic.asp?P=8880stk01
[Image: 8880stk01.jpg?0]
[Image: a0111809_5044a8073b02b.png]
I found some ldraw sticker parts for 8880 except for on the nose of the car. (next to V8 horizontal black stripes in yellow)
Anybody know where the sticker is?
Re: bb572c01 Electric motor - Philippe Hurbain - 2012-09-18
Servo motor is done!
[Image: 99498.png]
Thank you so very much alot :) - Oh-Seong KWON - 2012-09-18
Thank you so very much alot Smile
The time to assemble Crawler is coming if bb571c01 was made.
(((Undone))) 93575 Hero Factory Fist with Axle Hole - Oh-Seong KWON - 2012-10-04
http://www.bricklink.com/catalogItemPic.asp?P=93575
http://www.bricklink.com/catalogItem.asp?P=93575
I need this part to complete 10227 B-Wing.
Please, An able-man make this part as soon as possible.
[Image: a0111809_506cd39a3c874.jpg]
Re: Thank you so very much alot :) - Philippe Hurbain - 2012-10-13
...and large motor too:
[Image: 99499.png]
Re: 99013pb01 - Philippe Hurbain - 2012-10-13
Working on both rotor blades...
Re: Thank you so very much alot :) - Oh-Seong KWON - 2012-10-17
GREAT!!!
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
Re: 99013pb01 - Oh-Seong KWON - 2012-10-17
You are my hope, my savior ! Wink
Re: 99013pb01 - Philippe Hurbain - 2012-10-17
Wink
Rotor blades are both available now, but there's a question about their orientation, which may change...
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=99012
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=99013
Re: 99013pb01 - Oh-Seong KWON - 2012-10-18
You always give me happiness.
THANK YOU SO MUCH Smile
Re: 56908 - Philippe Hurbain - 2013-02-18
Working on it...
Re: 56908 - Oh-Seong KWON - 2013-02-18
Thanks alot Smile
Re: 56908 - Philippe Hurbain - 2013-02-26
Done! Phew :p
[Image: 56908.png]
Re: 56908 - Oh-Seong KWON - 2013-02-27
Great Job ^^b
Thank you very much Smile
[Done] 32494 Steering CV Joint - Oh-Seong KWON - 2013-03-29
[Image: 32494.jpg]
http://www.bricklink.com/catalogItem.asp?P=32494
32494.dat Technic, Steering CV Joint
I can't find this file at part tracker yet.
KWON
[Done] 11950 Steering Portal with 2 Pin Holes - Oh-Seong KWON - 2013-03-29
[Image: 11950.jpg]
http://www.bricklink.com/catalogItem.asp?P=11950
11950 .dat Technic, Steering Portal with 2 Pin Holes
KWON
[Done] 11949 Steering Portal with 2 Pin Holes and 2 Ball Joint Arms - Oh-Seong KWON - 2013-03-29
[Image: 11949.jpg]
http://www.bricklink.com/catalogItem.asp?P=11949
11949.dat Technic, Steering Portal with 2 Pin Holes and 2 Ball Joint Arms
KWON
Re: 11949 Steering Portal with 2 Pin Holes and 2 Ball Joint Arms - Philippe Hurbain - 2013-03-29
Hi KWON,
32494 is official since 2009. The two other parts are on my to-do list, but I'm presently very busy (at least till May) with EV3 stuff...
Re: 32494 Steering CV Joint - Santeri Piippo - 2013-03-31
Oh-Seong KWON Wrote:32494.dat Technic, Steering CV Joint
That's because it's in the official library instead. Time to update? Smile
EDIT: oops, beaten to it by days. I'm still blind. Sad
Re: 32494 Steering CV Joint - Oh-Seong KWON - 2013-04-01
Thanks for comment Smile
Re: 11949 Steering Portal with 2 Pin Holes and 2 Ball Joint Arms - Oh-Seong KWON - 2013-04-01
I am glad that you are aware of these two part Smile
Re: 11950 Steering Portal with 2 Pin Holes - Philippe Hurbain - 2013-05-16
This one is done!
[Image: 11950.png]
Re: 11950 Steering Portal with 2 Pin Holes - Oh-Seong KWON - 2013-05-16
Great! Thanks alot Smile
Re: 11949 Steering Portal with 2 Pin Holes and 2 Ball Joint Arms - Philippe Hurbain - 2013-05-30
Phew Tongue
This one was tough...
[Image: 11949.png]
Re: 11949 Steering Portal with 2 Pin Holes and 2 Ball Joint Arms - Oh-Seong KWON - 2013-06-03
Thank you s~~~~~~~~~~oooooo much !!!! Smile
Re: Technic Part Request (Anchor) - Stan Isachenko - 2013-06-06
Everyone forgot about http://www.bricklink.com/catalogItemPic.asp?P=93575.
I am to busy last time, so I have no time to do it, but hope someone haveSmile
