LDPatternCreator - Release 1.3.3 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: LDPatternCreator - Release 1.3.3 (/thread-4460.html) |
LDPatternCreator - Release 1.3.3 - Nils Schmidt - 2012-04-17 Hey, Here is the new LPC 1.3.3. Please uninstall older versions of this software before installing a new version. Your configuration won't be deleted if you have already version 1.3.2 installed on your machine. Change log: New features:
(see full list of tickets for 1.3.3) I included a short README.pdf in the installation directory. Cheers & Leg Godt Nils Re: LDPatternCreator - Release 1.3.3 - Daniel Goerner - 2012-04-18 Thanks Nils. Another suggestion: It would be really cool to have the ability to choose a bunch of vertices and arrange them on a X or Y coordinate to get them in a straight line. So when I choose the X coordinate the Y coordinate would be left alone, and vice versa. Re: LDPatternCreator - Release 1.3.3 - Philippe Hurbain - 2012-04-18 This could be done with the x-y coordinates box that appears when there is only one vertex selected. With multiple selection it could appear with blank values if vertices have different x or y values, but once you type in one box, the value is affected to all vertices. There is a convoluted method of doing this now: - Select all vertices you want to align - Create triangles between them - Select triangles and group them - select group and (in coordinate box) change top left 1.0000 to 0.00000001 (you can't use 0) for x direction (the middle bottom 1.000 for y direction) - Ungroup - Delete triangles. I guess it's as simple to select all vertices one by one and type in the same coordinate for all of them... BTW, Nils, there is a little "misfeature" there: cut and paste values doesn't work in coordinates box, you cut and paste vertices instead. Re: LDPatternCreator - Release 1.3.3 - Daniel Goerner - 2012-04-18 Oh, and you can't use the "del" key in the vertex-data box. I don't know why, but it would be nice if I could. Re: LDPatternCreator - Release 1.3.3 - Nils Schmidt - 2012-04-18 Daniel Görner Wrote:Oh, and you can't use the "del" key in the vertex-data box. I don't know why, but it would be nice if I could. Philippe 'Philo' Hurbain Wrote:BTW, Nils, there is a little "misfeature" there: cut and paste values doesn't work in coordinates box, you cut and paste vertices instead. I fixed these "misfeatures" today ![]() I have also spotted a bug when I undo / redo my work. This bug can crash the application. - Be careful! 1.3.4 will include a fix for the mentioned problems and I am going to release it on 2012/04/27. If necessary, make further proposals to improve my program. I will do my best to implement it. Re: LDPatternCreator - Release 1.3.3 - Mikkel Bech Jensen - 2012-04-22 I have a quick question. can you make patterns over studs? It would be very usefull for making patterns for baseplates. Allso I find it very defficult to create the templates. The manual doesn't explain well how to find the the exact x & y coordinates I need for the template. I am new to this part authoring and I really hope this program can get me started.
