Convertng Ldraw files into Solidworks or Famos or Step format - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: Convertng Ldraw files into Solidworks or Famos or Step format (/thread-4447.html) |
Convertng Ldraw files into Solidworks or Famos or Step format - aaburouss - 2012-04-17 Hi guys, Is it possible to convert the Ldraw data into step format t be opened with Solidworks or eventually in Famos (robotics software, supports *.prt,*.asm,*.neu,*.des,*.g,*.igs, *.iges,*.catia-iges,*.sat,*.stp,*.step,*.x_t,*.vda,*.igp,*.stl). I've tried converting the Ldraw to .dxf with the ldr. to dxf converter, to open it in Solidworks, but that didn't work. I wouldappreciate any suggestions. Thaks a lot Abdallah Re: Convertng Ldraw files into Solidworks or Famos or Step format - Philippe Hurbain - 2012-04-17 I think the best choice is LDview, it can export to .stl Re: Convertng Ldraw files into Solidworks or Famos or Step format - mmmak - 2012-05-10 thats a good news, thank you so much p.s. i could convert file for rendering software |
