LDView 4.2 Beta 1 Released - Printable Version
+--- Thread: LDView 4.2 Beta 1 Released (/thread-4278.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12
Re: LDView 4.2 Beta 1 Released - Roland Melkert - 2012-07-10
Bit of an open door but: You might be loosing the OpenGL context somehow.
Re: LDView 4.2 Beta 1 Released - Travis Cobbs - 2012-07-10
Could you try the 32-bit version? I don't have access to a 64-bit XP machine for testing, and I haven't seen anything like that in Vista or Windows 7.
Thanks for the suggestion. I don't think I recreate the OpenGL context when the toolbar is toggled, but I'll have to check my code to be sure. I think I just show/hide the bar windows, and then resize the OpenGL window. (In LDView, the OpenGL window is a borderless sub-window of the main LDView window so that it's out of the way of the optional toolbar and status bar.)
Re: LDView 4.2 Beta 1 Released - Christoph Mierowski - 2012-07-10
So I tried the 32-bit version its works all fine- but like other already mentioned only over legacy install
I reported the bug of the 64-bit version so that the stable release of 4.2 don't will have this bug - It's no problem to use until the release of this one the 32 bit version....
Only thought that the 64-bit version could use more than one core (which could maybe an advantage with a i5 quadcore)....
All three versions will use more than one core, but LDView only uses multiple cores for transparency sorting (one extra core) and conditional edge line calculations (as many cores as are available). So, under many circumstances, it won't visibly be using all the cores.
Since I don't have access to a dev machine with XP 64, it's very unlikely I'll be able to track down the source of your problem before the official release, but thank you for reporting it. I really do appreciate all bug reports.
Re: LDView 4.2 Beta 1 Released - Arthur Sigg - 2012-08-06
Windows 7 Home Premium 64-Bit / i7 950 /12 GB DDR3 SDRAM / Nvidia GeForce 460 (2x) / Samsung Syncmaster P2770
I was in despair ! I had a lot of troubles with LPub 4.0.0.11 in conjunction with LDView 4.1. With a relative complex design using a submodel repeated several times LPub was not able to finish up without crashing after about 80% of instructions generating. Reducing quality in LDView was helping a little bit but couldn't solve the problem. So I "discovered" your announcement about LDView 4.2 Beta and tried out the 64-Bit version. The result is phenomenal ! It runs 3 to 5 times faster and all the problems with cooperating between LPub and LDView are blown away !
Thanks Travis for this great upgrade ... You are the knight in shining armor :-)
Arthur
If you are able to "give away" some computing capacity install BOINC and help scientists to find a needle in a haystack (e.G. LIGO Laser Interferometer Gravitational Wave Observatory)
Re: LDView 4.2 Beta 1 Released - Philippe Hurbain - 2012-12-11
Any news on this?
Re: LDView 4.2 Beta 1 Released - Travis Cobbs - 2012-12-11
Sorry, but no. It seems unlikely it will make it into the official 4.2, though, given how little time I've had to work on LDView lately, and how long it's taking me to get it out the door.
Re: LDView 4.2 Beta 1 Released - Philippe Hurbain - 2012-12-12
Sad
...But I can easily understand you!
Re: LDView 4.2 Beta 1 can't export to povray - Patricia Moya Nosquera - 2013-01-03
LDView 4.2 beta1 can't export to povray correctly, I only get a contour:
[Image: busespacialmal.png]
It did work with older versions but now I use ubuntu 12.04 LTS 64 bits and older versions don't work anymore.
This is my hardware:
lspci
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 3 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
00:1d.3 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation 82801I (ICH9 Family) Thermal Subsystem (rev 03)
04:00.0 Network controller: Broadcom Corporation BCM4312 802.11b/g LP-PHY (rev 01)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
