LDView 4.2 Beta 1 Released - Printable Version
+--- Thread: LDView 4.2 Beta 1 Released (/thread-4278.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12
Re: LDView 4.2 Beta 1 Released - Travis Cobbs - 2012-05-11
You're welcome. Glad to hear it works. I'll include PPC in the official 4.2 release.
Re: LDView 4.2 Beta 1 Released - Philippe Hurbain - 2012-05-13
I just tried to add a link to LDView in "file converters" section of LDraw website (I'm a bit tired of suggesting it to people that need to convert LDraw to other 3D formats Wink, but I couldn't ("ERROR: This URL is already listed in the database!"). Any way around?
Re: LDView 4.2 Beta 1 Released - Orion Pobursky - 2012-05-13
Just wait a little while longer and we're going to switch to the new site
Re: LDView 4.2 Beta 1 Released - Patricia Moya Nosquera - 2012-05-20
Any plans to port LDView to android?
I find this for java, but seems beta and dificult to compile for non-java programmers:
http://www.youtube.com/watch?v=bHahOgDz7TQ
http://code.google.com/p/foo-org-ve/
By the way, version 4.2b1 runs ok on Ubuntu 12.04, ¬°good job!
Regards
Re: LDView 4.2 Beta 1 Released - Travis Cobbs - 2012-05-21
pillabichos Wrote:Any plans to port LDView to android?
No. I have no Android devices, and don't really plan to have any. Also, a port would be fairly difficult, since talking to native C++ code (which LDView is) from Java isn't very nice. Until two other LDraw viewers showed up for iOS, I had considered an iOS port, but iOS programs can easily talk to native C++ code.
pillabichos Wrote:I find this for java, but seems beta and dificult to compile for non-java programmers:
If someone wants to make something out of that for Android, that's fine, but it wouldn't be LDView, since it's not related. And I won't be doing it; I used Java in my job for a while, and never grew to like it, so I'm not likely to do it for fun.
pillabichos Wrote:By the way, version 4.2b1 runs ok on Ubuntu 12.04, ¬°good job!
Thanks. I'm glad it works there.
Re: LDView 4.2 Beta 1 Released - Philippe Hurbain - 2012-05-21
If you have an edge line overlapping a condline (eg. when a portion of cylinder meets a quad at an angle), it would be great if the smoothing action of the condline was disabled...
Thanks for the suggestion. I definitely agree, but I'm not sure how easy it will be to implement. I'll investigate.
Re: LDView 4.2 Beta 1 Released - Christoph Mierowski - 2012-07-10
I have some problems with this beta version,too. I'm running WinXP 64-bit and when I start the Ldview64.exe and load a model I don't see any thing. But if I switch to fullscreen I see my model perfectly. I also see it without problems when I turn the toolbar off. In that moment I turn the toolbar on it disappears again.
Re: LDView 4.2 Beta 1 Released - Travis Cobbs - 2012-07-10
Yours is the first report of behavior like this, and I'm somewhat at a loss as to how to track down the problem. I do notice that when I toggle the toolbar, the model disappears, but as soon as I do anything after that, it reappears. I'll investigate fixing this, but it doesn't sound like the problem you're seeing. If you click and drag in the blank model area, does the model appear?
If I click in the blank area nothing happens- also the toolbar is cut off after the previous step button when I toggle the toolbar on again. And sometimes when I start LDView with toggled on toolbar I don't see the toolbar itself....
I also can not drag and drop a model file into LDView as long as the toolbar is on- there is no problem when the toolbar is off...
Don't now if this only a problem under WinXP 64 bit?
By the way I have OpenGL 4.2.0
