7812p01 – Falcon canopy print inaccuracies - Printable Version
+--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html)
+--- Thread: 7812p01 – Falcon canopy print inaccuracies (/thread-29718.html)
7812p01 – Falcon canopy print inaccuracies - Eric Parsons - 2026-11-23
Hello, first time posting here, so apologies if this is the wrong way to go about reporting an issue.
The print on https://library.ldraw.org/parts/52523 is inaccurate. In the attachments, you can see an image I clipped from New Elementary's review on this part (https://www.newelementary.com/2026/04/new-molds-in-lego-star-wars-smart-play.html) and I rendered this part in the same angles for you to compare.
Issues:
1) The front part of the print is up higher than the rear.
2) The center transparent section needs to be much wider, forcing the two on each side down.
3) The transparent sections need to extend slightly back.
Hope this helps lock in this part for usage. Thanks!
