Anyone tracking how new patterned parts get named consistently? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html) +--- Thread: Anyone tracking how new patterned parts get named consistently? (/thread-29714.html) |
Anyone tracking how new patterned parts get named consistently? - Joseph Miller - 2026-11-20 I have been following the Parts Tracker for a while and keep noticing how patterned elements get split into separate subparts before they land in an official library. My own small project uses a handful of printed torso and tile patterns, and I want to make sure the naming I use locally lines up with what eventually gets published, since renaming later breaks my references. What I keep running into is uncertainty about when a pattern should become its own subpart versus staying as a single decorated part. I have seen both approaches in the tracker, and I am not sure which one holds up better for reuse across multiple colors or shapes. I do not want to submit anything that creates extra cleanup work for reviewers. For anyone who has watched this process, how do you decide the right structure before submitting, and are there common naming pitfalls I should avoid? I would appreciate hearing how others handle this. |
