Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Printable Version
+--- Thread: Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back (/thread-29661.html)
Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Madi L - 2026-10-14
Hiya,
I'm working on a project that I want to document in BrickLink Stud.io, and have been looking at the part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back (see picture below), which is a new part from the Iron Man and His Awesome Friends line. It appears to be currently in the process of being added to LDraw, hence its absence in Stud.io.
I'd be happy to work on the part myself, but I've never interfaced with LDraw and don't really know where to start. Is there any chance that anyone would be willing to either help me get the part figured out and/or help me get started working on it myself?
RE: Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Peter Grass - 2026-10-16
If you just want the basic raw part it is here:
https://forums.ldraw.org/thread-29267.html
RE: Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Chris Böhnke - 2026-10-16
Do you already have the following programs?
  • Full LDraw Installation (including LDView)
  • Latest parts update
  • LDraw Parts Editor (LDPE)
  • text editor of your choice (like Windows Editor or Notepad++)
It would also help greatly if you have a copy of the real part for reference (especially verifying connection points). If not, you might want to get some images of real ones online (Bricklink has at least back and front).
Have you considered working on a more simpler part first? It's hard to tell at this stage, but it's probably a challenging one for the start.
RE: Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Madi L - 2026-11-19
(2026-10-16, 21:50)Chris Böhnke Wrote: Do you already have the following programs?
I don't have either of the relevant LDraw programs; to be frank, life hit me like a truck the last couple of weeks.
I do have a copy of the real part, fortunately, both on a MOC and in my parts.
To be perfectly honest, I just want to get this part because, as near as I can tell, it's the only part that I need for the MOC that I'm trying to put into Stud.io that isn't already handled for use in the software.
RE: Part 8018 - Cockpit 3 x 6 x 4 with Pin Hole, Inverted Studs on Back - Peter Grass - 2026-11-19
If you need the part I already gave you the place to find the raw file which is good enough to use for a MOC. You just have to import it into the part designer and add the connectors and then export it into studio so it shows as a custom part.
