[Studio] Documentation for .conn and .col files ? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: [Studio] Documentation for .conn and .col files ? (/thread-29464.html) |
Documentation for .conn and .col files ? - alphonse - 2026-03-27 Hello, I'm trying to code my own Lego building engine, and I need to parse .conn and .col files of the parts in order to reproduce the brick snaping feature. Do you guys know if there is some documentation about how to read .conn and .col files ? I found this discussion that helped me but it misses some points https://forums.ldraw.org/thread-28521-post-59984.html#pid59984 I also found another discussion about .col files, but same issue, it is not complete :/ Ideally, I would like to be able to scan a .mpd file and get all the available positions for a chosen brick. Thank you, Alf RE: Documentation for .conn and .col files ? - Orion Pobursky - 2026-03-27 Despite repeated requests to the Studio team, there is not. I recommend asking on the Studio fourms. Maybe if enough people ask, they'll actually listen. RE: Documentation for .conn and .col files ? - Sylvain Sauvage - 2026-03-28 There’ll need to be a lot of supporting comments to be considered. “The code is the spec.” But we don’t have access to the code and the devs don’t have the time to write a doc 🤷♂️ |
