[Studio] Tip on where to put "0 BL_Item_No" - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: [Studio] Tip on where to put "0 BL_Item_No" (/thread-29409.html) |
Tip on where to put "0 BL_Item_No" - Hageta - 2026-02-25 When you use Bricklink Studio with custom parts and want Studio to show you the available colours you need a meta command for the bricklink item number. The metacommand is the following(5272pb01 is an example part number): Code: 0 BL_Item_No 5272pb01 |
