Keywords and invalid 0 lines - Printable Version
+--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html)
+--- Thread: Keywords and invalid 0 lines (/thread-29152.html)
Keywords and invalid 0 lines - Orion Pobursky - 2025-11-02
I'm considering implementing the following automatic upon submit edits:
- Remove all lines that consist of a single "0" and replace with a blank line
- Remove all lines that are "0 //" (i.e. a blank comment) and replace with a blank line
- If the last line is a single "0", remove completely
- Capitalize the first word for all keywords.
Thoughts?
RE: Keywords and invalid 0 lines - Franklin W. Cain - 2025-11-03
(2025-11-02, 23:47)Orion Pobursky Wrote: - Capitalize the first word for all keywords.
If the search function is not case-sensitive, would this one really matter?
(And if the search function actually =is= case-sensitive, and I've not known this until now, then I'd argue for Title Capitalization, instead of Sentence Capitalization.)
Thanks!
Franklin
RE: Keywords and invalid 0 lines - Orion Pobursky - 2025-11-03
Search is not case sensitive. This is more for consistency than anything else.
RE: Keywords and invalid 0 lines - Peter Blomberg - 2025-11-03
(2025-11-02, 23:47)Orion Pobursky Wrote: I'm considering implementing the following automatic upon submit edits:
Sure, if you account for random whitespace after the "0" or the "0 //"
Can this be done also for all official files? (without having the go through the review process)
RE: Keywords and invalid 0 lines - Rene Rechthaler - 2025-11-03
Thoughts?
if a line gets edited empty, will two consecutive empty lines also get shortened to one empty line?
(and empty last lines could be always deleted)
Rene Rechthaler Wrote: if a line gets edited empty, will two consecutive empty lines also get shortened to one empty line?
Peter Blomberg Wrote: Sure, if you account for random whitespace after the "0" or the "0 //"
All submitted files get the following processing:
- Non-standard UTF-8 encoding gets fixed
- Extra white space on the front and back of the whole file is trimmed
- All line endings are changed to unix style (make it easier edit in code, they get changed back when downloaded)
- Extra white space on the front and back of each line is trimmed
- Multiple, consecutive newlines are squished into one new line.
- Except for the first line (the description), all extra white space between non-whitespace characters is squished to one space
Peter Blomberg Wrote: Can this be done also for all official files? (without having the go through the review process)
A script has been written to do just this.
I reviewed the code. It seems I forgot that I have already implemented the stripping of blank comments (both "0" and "0 //") for new submits.
The script to fix existing parts has not yet been run (that will happen close to the next release).
