Duplo cannon ball part naming - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Duplo cannon ball part naming (/thread-28960.html) |
Duplo cannon ball part naming - Peter Blomberg - 2025-07-25 BrickLink lists two duplo cannon balls: 54043 Duplo Cannon Ball 1/2 with Large Axle Connector 54043b Duplo Cannon Ball 1/2 with Large Axle Connector and 4 Holes in Top These parts have visibly different geometry, the newer is more reinforced and has 4 holes. How should they be numbered in LDraw? Keep 54043 and 54043b or go with a and b versions? RE: Duplo cannon ball part naming - Gerald Lasser - 2025-07-25 (2025-07-25, 16:45)Peter Blomberg Wrote: BrickLink lists two duplo cannon balls: The b version is available as BI mesh. It looks very much like the 54043, also the locking ratchet. The reinforcement is also present on y the older part, the render of the older part however doesn't show it. a/b is ok, if necessary, we can rename |
