LDraw All-In-One-Installer 2025-02 v1 now available - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: LDraw.org Announcements (https://forums.ldraw.org/forum-1.html) +--- Thread: LDraw All-In-One-Installer 2025-02 v1 now available (/thread-28952.html) |
LDraw All-In-One-Installer 2025-02 v1 now available - Willy Tschager - 2025-07-20 An updated version of the LDraw All-In-One-Installer, in short AIOI, containing the LDraw Parts Library Updates from 2025-02 to 2025-06. The AIOI supports Windows XP (Home and Pro), Windows Vista or higher (all versions). There are two installer files available: Use the 64 Bit AIOI to install all the main 64 Bit programs, while the older 32 Bit programs are offered in a separated .exe file. Please note that only the 64 Bit version contains the LDraw Parts Library. If you want to use the 32 Bit programs, it is mandatory that the library has been installed previously. The Installer will NOT run on Windows 95, 98, ME, NT Ver 4, 2000, or XP below SP2. It contains the following changes: * Update to Parts Library 2025-06 * Update to MLCad.ini 2025-06 * Update to Offline Parts Catalog 2025-06 You can download the AIOI from: LDraw.org >> Help >> Get Started >> Windows >> LDraw All-In-One-Installer Many thanks to all the programmers who contributed to this release. Willy Tschager (LDraw.org Content Manager) |
