[LPub] LPub3D, how to update or new installation - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: [LPub] LPub3D, how to update or new installation (/thread-28717.html) |
LPub3D, how to update or new installation - Manfred Schaefer - 2025-03-10 Hello, I am using LPub3D version 2.4.4 under Windows 10 and I wanted to update it, but the internal function 'Check for Updates' has no effect. I can find a zip file on the website in the download area, but it does not contain an installer. Can someone tell me how I can install this program in windows. Thank you. Greetings Manfred RE: LPub3D, how to update or new installation - Orion Pobursky - 2025-03-10 How did you install it originally? RE: LPub3D, how to update or new installation - Manfred Schaefer - 2025-03-10 (2025-03-10, 19:16)Orion Pobursky Wrote: How did you install it originally? Hello, I installed it two years ago with the LDraw All-In-One-Installer. It worked fine, but now I wanted update this software. RE: LPub3D, how to update or new installation - Manfred Schaefer - 2025-03-19 I had deleted the contents of the LPub3D program directory and pasted the contents of the ZIP file. That didn't work either, so I uninstalled everything and reinstalled it using the latest version of the All-IN-ONE installer. After that, it worked again. I found a bug in the program, which has already been fixed. I hope the update to the next version will work better. |
