Frame 3x13 and curved panel 3x9 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Frame 3x13 and curved panel 3x9 (/thread-28348.html) |
Frame 3x13 and curved panel 3x9 - Paweł Turalski - 2024-07-27 Hi guys! In August we get some new technic parts, I already have two of them in my 42173 Koenigsegg and I would ask to make them in digital form. The first one is the frame 3x13 - it is basically the shorter version of the previous longer, so I think it should be easy to do: Next one is the cuved panel 3x9 - slightly different than 3x11 but here are the key differences: The outside parts is smooth, there is no "grille" anymore, on the opposite there are 4 small dots: When you compare them both in the middle, you can see the both parts have the same height: And it fits to the mudguard 2459: The part numbers are visible, I hope there are possible to read: But if not, Frame: 4526 Panel: 5427 Thanks in advance! RE: Frame 3x13 and curved panel 3x9 - Jeff Jones - 2024-07-27 the liftarm's now on the tracker maybe i would do the panel RE: Frame 3x13 and curved panel 3x9 - Gerald Lasser - 2024-11-14 all parts on tracker https://library.ldraw.org/parts/39917 |
