Sticker shortcut standard - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Official File Specifications/Standards (https://forums.ldraw.org/forum-32.html) +--- Thread: Sticker shortcut standard (/thread-28281.html) |
Sticker shortcut standard - Orion Pobursky - 2024-05-30 Our current rules on sticker shortcuts are: Quote:- The shortcut may not include more than one part, although that part may be a shortcut part.Note: The second and third items have been superseded and will be removed. This doesn't encapsulate the standard practices with sticker shortcuts. The current practice is as follows: - The part and the sticker should be color 16 - If the part is an assembly of a color 16 part and a transparent part and the sticker is placed on the transparent area: - For a solid color sticker, the color will be the color of the sticker back (usually white) - For a transparent sticker, the color will be Trans_Sticker RE: Sticker shortcut standard - Orion Pobursky - 2024-05-30 I think the stickers in sticker shortcuts should not be color 16 but be their proper color from the sticker sheet. Otherwise, there will be an issue if the user chooses to make the parts transparent. It also avoids the convoluted coloring rule above. RE: Sticker shortcut standard - Magnus Forsberg - 2024-05-30 (2024-05-30, 17:10)Orion Pobursky Wrote: I think the stickers in sticker shortcuts should not be color 16 but be their proper color from the sticker sheet. Otherwise, there will be an issue if the user chooses to make the parts transparent. It also avoids the convoluted coloring rule above. Then all printed bricks should have the print in BFC NOCLIP. I think we should only have coloured stickers on transparent (sub)parts. RE: Sticker shortcut standard - Orion Pobursky - 2024-05-30 To be clear, I'm fine with the current way and am not strongly advocating for change. RE: Sticker shortcut standard - Philippe Hurbain - 2024-11-15 (2024-05-30, 15:07)Orion Pobursky Wrote: Our current rules on sticker shortcuts are:These items are still in https://www.ldraw.org/article/512.html#sticker_desc RE: Sticker shortcut standard - Orion Pobursky - 2024-11-15 (2024-11-15, 8:28)Philippe Hurbain Wrote: These items are still in https://www.ldraw.org/article/512.html#sticker_desc Fixed. |
