Boat Connectors for Hull and Deck - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Boat Connectors for Hull and Deck (/thread-28234.html) |
Boat Connectors for Hull and Deck - Gerald Lasser - 2024-05-01 One of the topics we touched during the Billund24 meeting was the level of detail withing the boat hullls. Usually there are some filltes there to strengthen the hull, some compartments that provide bouyancy (with the top attached) and of course the interlocking thingy. Those interlocking fingers have been introduced in 2003/4 and are present ever since in basically all the floating hulls. Although mainly invisible, in my opinion we should have the choice to show them. To make this easier I have come up with a set of primitives that allow an easy use, even when scaling is necessary.
To name them I proposed a scheme as follows:
e.g.: "Boatlock Bottom Connector Quarter" Filename "boat-b-connq" suggestions are welcome Here's an overview: Usage plain Usage inclined surface I will upload them to the PT and let's see from there RE: Boat Connectors for Hull and Deck - Willy Tschager - 2024-05-01 (2024-05-01, 12:13)Gerald Lasser Wrote: Although mainly invisible, in my opinion we should have the choice to show them. IMHO you're wasting your time. w. RE: Boat Connectors for Hull and Deck - samson williams - 2024-05-08 Very detailed, thank you. |
