wheels+tyres: correct the 6 odd files out of 320+ - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: wheels+tyres: correct the 6 odd files out of 320+ (/thread-28179.html) |
wheels+tyres: correct the 6 odd files out of 320+ - Steffen - 2024-03-25 Hi LDRAW friends, when looking at our wheels+tyres collection...: ...you will notice that 6 out of the 320 files are wrongly oriented (marked in pink). As that number is very small, I think it would be acceptable to create corrected variants of these 6 (as NEW part files, of course, to not break existing models) and make the wrongly oriented ones a MOVED-TO to the correct ones. The new part number would simply be adding a "...b" suffix to the existing one. I would like to volunteer to do this, but first I would like to request an OK for this from the other experienced parts authors / the SteerCo Opinions? It is just 6 files and would make our library consistent. I would be very happy looking at the wheels above and see them all oriented the same way. ...Steffen RE: wheels+tyres: correct the 6 odd files out of 320+ - Steffen - 2024-03-25 the "...b" variants with corrected orientation are now on the PT: https://library.ldraw.org/tracker/parts/2573b.dat https://library.ldraw.org/tracker/parts/30028b.dat https://library.ldraw.org/tracker/parts/3139b.dat https://library.ldraw.org/tracker/parts/3464b.dat https://library.ldraw.org/tracker/parts/3739b.dat https://library.ldraw.org/tracker/parts/451b.dat the 6 MOVED-TO files have been sent to PT admin RE: wheels+tyres: correct the 6 odd files out of 320+ - Magnus Forsberg - 2024-03-25 How about all the shortcuts now using the moved part? Don't they also need to be updated and not use the Move to-part? RE: wheels+tyres: correct the 6 odd files out of 320+ - Steffen - 2024-03-25 (2024-03-25, 21:21)Magnus Forsberg Wrote: How about all the shortcuts now using the moved part? Of course, this can be done in a later step. This always occurs when adding a MOVED-TO. I can do that if wanted. I'll probably wait with that until the 6 wheels + their MOVED TOs have accumulated enough CERT votes. The MOVED-TO files of course contain the proper matrix to map the new ...b files to the old (wrong) orientation. |
