Minifig Hips and Legs with Pearl Grey Wooden Leg Right Pattern - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Minifig Hips and Legs with Pearl Grey Wooden Leg Right Pattern (/thread-27504.html) |
Minifig Hips and Legs with Pearl Grey Wooden Leg Right Pattern - Willy Tschager - 2023-06-19 Guys, we have a bit of mismatch between: https://library.ldraw.org/tracker/31943 https://library.ldraw.org/tracker/31944 https://library.ldraw.org/tracker/31945 BL distinguishes between: https://www.bricklink.com/catalogList.asp?catType=P&catString=1116 Hips and 1 Black Left Leg, 1 Flat Silver Pirate Peg Leg Hips and 1 Black Left Leg, 1 Pearl Dark Gray Pirate Peg Leg Hips and 1 Black Left Leg, 1 Pearl Light Gray Pirate Peg Leg * Hips and 1 Black Left Leg, 1 Pearl Light Gray Pirate Peg Leg https://www.bricklink.com/catalogItemIn.asp?P=970d05&in=S comes just in 4767 and can be found also in Brickset: https://brickset.com/parts/4268451/hip-w-wooden-leg-col-131 * Hips and 1 Black Left Leg, 1 Flat Silver Pirate Peg Leg https://www.bricklink.com/catalogItemIn.asp?P=970d16&in=S seams to be limited to LEGENDS OF CHIMA and would probably corrispond to 179 - Pearl_Silver Brickset lists it as: https://brickset.com/parts/4624825/hip-w-wooden-leg-left-leg * Hips and 1 Black Left Leg, 1 Pearl Dark Gray Pirate Peg Leg https://www.bricklink.com/catalogItemIn.asp?P=970d12&in=S looks almost identical to the above and would corrispond 147 - to Pearl_Dark_Grey Brickset lists it as: https://brickset.com/parts/6237256/hip-w-wooden-leg-left-leg Do you thing this is correct? Any comments are welcome. w. RE: Minifig Hips and Legs with Pearl Grey Wooden Leg Right Pattern - Orion Pobursky - 2023-06-19 I don't see a problem and the new 'p' numbers correspond to our old 'c' numbers |
