Converting .dat files to .obj using LeoCAD - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: Converting .dat files to .obj using LeoCAD (/thread-27296.html) |
Converting .dat files to .obj using LeoCAD - Luke - 2023-04-12 Hi, I am trying to convert bricks to .obj format. LeoCAD has this export option, however, for some parts it raises an error "Nothing to export". E.g. when I load part 4073 from .dat file, it can be exported just fine, but not part 3023. I get the same error when I try to render it. What are the reasons for such inconsistent behaviour and is there a way to fix it? |
