Get flex out there - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Get flex out there (/thread-2696.html) |
Call for reviews Re: Get flex out there - Tim Gould - 2011-12-23 OK. Please review http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/22296.dat. Once it's done I'll upload all the others. They'll all be as right or wrong as this one. Tim Other part families Re: Get flex out there - Tim Gould - 2012-01-01 What other parts need a similar treatment? I've already modded the code to deal with flexibile hose with 0 Technic Ribbed Hose XX Ribs but it's easy to modify for other standardised parts. Tim PS. perl code below for anyone who wishes to do their own sets Code: use POSIX; Re: Get flex out there - Joshua Delahunty - 2013-04-16 Tim Gould Wrote:Ahhhh... with all the sense that entails. 5L = 76307, 6L = 76279, 7L = 76289, ... 76307 should be 70859 70859 Outer cable for TECHNIC 40mm 47040 Outer cable 40mm, red 47042 Outer cable 40mm, blue 47420 Outer cable 40mm, yellow 51976 Outer cable 40mm, dark stone grey 76307 Outer cable 40mm, dark grey 76279 should be 70860 (76279 is Outer cable 48mm, black) 76289 should be 70861 (76289 is Outer cable 4mm, dark grey) -- joshua |
