finding part - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: finding part (/thread-26922.html) |
finding part - Sparky678911 - 2022-12-20 Evening all would like some help i want a flex-system hose that i can bend how i want the one i have circled is normal i can not bend the one on far left is too big where or is there one thanks for help RE: finding part - David Manley - 2022-12-20 (2022-12-20, 22:06)Sparky678911 Wrote: Evening all would like some help i want a flex-system hose that i can bend how i want the one i have circled is normal i can not bend the one on far left is too big where or is there one thanks for help You may want to use a template via the parts bin, as follows: ![]() in conjunction with reading the section titled "Dynamic Parts" on Roland's Advanced Editing webpage. RE: finding part - Sparky678911 - 2022-12-21 thanks for reply but on mine for some reason they look strange not the same as yours
RE: finding part - N. W. Perry - 2022-12-22 (2022-12-21, 19:07)Sparky678911 Wrote: thanks for reply but on mine for some reason they look strange not the same as yours Looks like you're missing a valid search location for Donors. You can check under Prefs->LDraw->Search (library) paths… Is there an entry for Donors there? RE: finding part - Sparky678911 - 2022-12-22 this is what i have in there RE: finding part - N. W. Perry - 2022-12-23 (2022-12-22, 18:39)Sparky678911 Wrote: this is what i have in there Ah, it's showing as an Unofficial library rather than Donors. Try choosing the "donors" type option (the row of buttons), then re-launch LDCad and see if it's better. RE: finding part - Sparky678911 - 2022-12-23  perfect thank you
