RCX 1.0/1.5/2.0 Modules - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: RCX 1.0/1.5/2.0 Modules (/thread-26565.html) |
RCX 1.0/1.5/2.0 Modules - Orion Pobursky - 2022-07-18 Here's a guide to numbering for the RCX modules for someone looking to create 1.5 and 2.0: RCX 1.0 module: 76048: Complete Assembly 32109 (already made): Battery cover 32110: IR "glass" on the front 32116: The green, lower part where the batteries go 32058: The yellow, upper part without the clear plastic screen protector and unprinted 32058p01: 30258 with RCX 1.0 Pattern 32108: The clear plastic screen protector 76113: The yellow, upper part with the clear plastic screen protector 6554 (Already made): The electrical plates, plastic portion 75212: 6554 plus the metal electrical contacts 71748: The circuit board 71645: The gray/green button assembly and the black/red button assembly Since the top of 884 (the full assembly) is hard coded yellow and I think that part should be color 16, we're going to obsolete 884 and create a new complete assembly with the correct number RCX 1.5 module: 76454 or 76454c01: Complete Assembly 32109 (already made): Battery cover 32110: IR "glass" on the front 32116: The green, lower part where the batteries go 32374: The yellow, upper part without the clear plastic screen protector and unprinted 32374p01: 32058 with RCX 1.5 Pattern 32108: The clear plastic screen protector 32374p01c01: The yellow, upper part with the clear plastic screen protector (no number known, unlike 1.0) 6554 (Already made): The electrical plates, plastic portion 75212: 6554 plus the metal electrical contacts ?: The circuit board 71645: The gray/green button assembly and the black/red button assembly RCX 2.0 module: 76454a or uXXXX or 76454c02 : Complete Assembly 32109 (already made): Battery cover 32110: IR "glass" on the front 32116: The green, lower part where the batteries go 32374: The yellow, upper part without the clear plastic screen protector and unprinted 32374p02: 32058 with RCX 2.0 Pattern 32108: The clear plastic screen protector 32374p02c01: The yellow, upper part with the clear plastic screen protector (no number known, unlike 1.0) 6554 (Already made): The electrical plates, plastic portion 75212: 6554 plus the metal electrical contacts ?: The circuit board 71645: The gray/green button assembly and the black/red button assembly This post will be update as numbers are known. RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-18 An image of the inside here: https://www.bricklink.com/myImg/776562.jpg RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-18 (2022-07-18, 16:45)Magnus Forsberg Wrote: An image of the inside here: https://www.bricklink.com/myImg/776562.jpg I have both a 1.0 and 2.0 so can provide pics as well. RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-18 Re-arranged the content accordingly. Don't think I can, or should, take it any further. RE: 884, RCX 1.0 Module - Max Martin Richter - 2022-07-18 Please note, that the battery compartment is very similar to the Code Pilot one. I think, the metal clamps could be even the same. RE: 884, RCX 1.0 Module - Philippe Hurbain - 2022-07-18 (2022-07-18, 19:30)Max Martin Richter Wrote: Please note, that the battery compartment is very similar to the Code Pilot one. I think, the metal clamps could be even the same.Yes they are. RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-18 What's the difference between 1.0 and 2.0? Are there version without the charge socket? Why do they have a 6 digit number code on the side? RE: 884, RCX 1.0 Module - Max Murtazin - 2022-07-18 (2022-07-18, 20:05)Magnus Forsberg Wrote: What's the difference between 1.0 and 2.0? There should be no differences besides 2.0 having better hardware as far as I'm aware RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-18 (2022-07-18, 20:05)Magnus Forsberg Wrote: What's the difference between 1.0 and 2.0? 1.0 is the only one with an AC socket. Also, 1.5 doesn't have 1.5 on the side. The 6 digit code is a serial number. Aside from that, I not aware of any other visual differences but Philo can correct me if I'm wrong. RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-19 Small update to the above: 32058: The yellow, upper part without the clear plastic screen protector and unprinted (the printed version has a number but for consistency we'll go with 32058p01) 71645: The gray/green button assembly and the black/red button assembly RE: 884, RCX 1.0 Module - Max Murtazin - 2022-07-19 (2022-07-19, 2:22)Orion Pobursky Wrote: Small update to the above: What is printed version's number is tho? RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-19 (2022-07-19, 2:28)Max Murtazin Wrote: What is printed version's number is tho? How deep are the 4 pinholes on the sides. Half pin or a whole regular pin 3749? Stud orientation? RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-19 (2022-07-19, 15:07)Magnus Forsberg Wrote: How deep are the 4 pinholes on the sides. Half pin or a whole regular pin 3749? They're 5.2mm deep. A half pin fits and clicks in, a full pin does not. RE: 884, RCX 1.0 Module - Philippe Hurbain - 2022-07-20 (2022-07-18, 21:24)Orion Pobursky Wrote: 1.0 is the only one with an AC socket. Also, 1.5 doesn't have 1.5 on the side. More precisely, the so called 1.5 (that came in robotics invention system 1.5) does have 1.0 on side, and lost the ac adapter plug. RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-20 (2022-07-20, 6:30)Philippe Hurbain Wrote: .... and lost the ac adapter plug. Sounds like a different mould. Same partnumber, 32058? If 76113 is the yellow, upper (printed) part with the clear plastic screen protector for 1.0 (and 1.5) , whats the number for the 2.0 with glass, but without AC port? RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-20 (2022-07-20, 12:58)Magnus Forsberg Wrote: Sounds like a different mould. Same partnumber, 32058? The mould for the 1.5 certainly seems like it would be different I'll see if it was discussed in the RCX discussion we had and figure it out if it wasn't RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-20 (2022-07-19, 23:29)Orion Pobursky Wrote: A half pin fits and clicks in, a full pin does not. Then the snap info in LDCad is not correct. But the geometry is. RE: RCX 1.0/1.5/2.0 Modules - Orion Pobursky - 2022-07-20 I've update the top post to include all the RCX variants with known numbers or what they will be in the library. RE: 884, RCX 1.0 Module - Magnus Forsberg - 2022-07-21 (2022-07-18, 17:23)Magnus Forsberg Wrote: Re-arranged the content accordingly. Don't think I can, or should, take it any further. This has now turned into the holliday project I'll be working on during the rainy days of the vacation .... RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-21 You're awesome. Your effort is always very appreciated RE: 884, RCX 1.0 Module - Orion Pobursky - 2022-07-21 We should probably hash out what to number 1.5 and 2.0 since they share a number for the complete assembly. I think 76454c01 and 76454c02 are the best options. RE: 884, RCX 1.0 Module - Max Murtazin - 2022-07-21 (2022-07-21, 21:42)Orion Pobursky Wrote: We should probably hash out what to number 1.5 and 2.0 since they share a number for the complete assembly. I think 76454c01 and 76454c02 are the best options. Looks like a fair option RE: RCX 1.0/1.5/2.0 Modules - Magnus Forsberg - 2022-08-30 (2022-07-18, 14:20)Orion Pobursky Wrote: 76113: The yellow, upper part with the clear plastic screen protector Should this number contain only 32058p01 + 32106 ? Or does it also contain the rest of what's now in 883 ? (2022-07-18, 14:20)Orion Pobursky Wrote: 32106: The clear plastic screen protector Is this correct? I think it might be 32108 instead. RE: RCX 1.0/1.5/2.0 Modules - Orion Pobursky - 2022-08-30 (2022-08-30, 20:49)Magnus Forsberg Wrote: Should this number contain only 32058p01 + 32106 ? Just 32058p01 + 32106 (2022-08-30, 20:49)Magnus Forsberg Wrote: Is this correct? I think it might be 32108 instead. Joshua wrote (multiple times) 32106. Is there a reason you might think different? RE: RCX 1.0/1.5/2.0 Modules - Magnus Forsberg - 2022-08-30 (2022-08-30, 21:18)Orion Pobursky Wrote: Joshua wrote (multiple times) 32106. Is there a reason you might think different? Yes. Did you get my message? I sent an image. RE: RCX 1.0/1.5/2.0 Modules - Magnus Forsberg - 2022-09-07 OK, 76113 is only 32058p01 + 32108 Then, IMHO, we should renumber current file 883.dat to 76113c01.dat. But using 32374p01c01 and 32374p02c01 on the top part without AC socket create a problem. I need a file to assemble the top part RCX 1.5 and 2.0. It would have to be 32374p01c01c01. Stupid. Should I use a u-number on the top with glass, and then create uXXXXc01 as the assembly? Or, do I keep 32374p02c01 as the top with glass, and use uXXXX on the assembly? RE: RCX 1.0/1.5/2.0 Modules - Orion Pobursky - 2022-09-08 (2022-09-07, 16:57)Magnus Forsberg Wrote: OK, I concur (2022-09-07, 16:57)Magnus Forsberg Wrote: keep 32374p02c01 as the top with glass, and use uXXXX on the assembly? I like this option. RE: RCX 1.0/1.5/2.0 Modules - Orion Pobursky - 2022-09-08 (2022-08-30, 20:49)Magnus Forsberg Wrote: Should this number contain only 32058p01 + 32106 ? Comfirmed. 32108. RE: RCX 1.0/1.5/2.0 Modules - Magnus Forsberg - 2022-09-10 All three are now at the Part Tracker. |
