"invisible" condlines for fine shading - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: "invisible" condlines for fine shading (/thread-26559.html) |
"invisible" condlines for fine shading - Max Murtazin - 2022-07-13 While modifying some stuff about part 50898, I have encountered a bit of a problem. There was a situation that required to use condlines with all points being on the same plane. It it okay? Or maybe there are some ways to work around such problems? If not use that condline at all, software like LDView gives off a pretty bad picture in terms of shading with edges appearing sharp when they clearly should be not that way RE: "invisible" condlines for fine shading - Gerald Lasser - 2022-07-13 (2022-07-13, 17:58)Max Murtazin Wrote: While modifying some stuff about part 50898, I have encountered a bit of a problem. There was a situation that required to use condlines with all points being on the same plane. It it okay? Or maybe there are some ways to work around such problems? If not use that condline at all, software like LDView gives off a pretty bad picture in terms of shading with edges appearing sharp when they clearly should be not that way While it is not a common practice, it is done from time to time, to avoid those artefacts. RE: "invisible" condlines for fine shading - Magnus Forsberg - 2022-07-13 (2022-07-13, 17:58)Max Murtazin Wrote: While modifying some stuff about part 50898, I have encountered a bit of a problem. There was a situation that required to use condlines with all points being on the same plane. It it okay? Or maybe there are some ways to work around such problems? If not use that condline at all, software like LDView gives off a pretty bad picture in terms of shading with edges appearing sharp when they clearly should be not that way I think the genaral rule of thumb is that a surface is considered flat if the angle between 2 triangles are less than 0.1 degree, and then no condline is allowed. We should not adapt the code in a file to shortcomings in specific software. But sometimes, some of us bend that rule by tweaking the code, or rather the surface. RE: "invisible" condlines for fine shading - Orion Pobursky - 2022-07-13 From an admin standpoint, I don't really care as long as this and similar practices remain firmly optional RE: "invisible" condlines for fine shading - Max Murtazin - 2022-07-13 (2022-07-13, 21:39)Orion Pobursky Wrote: From an admin standpoint, I don't really care as long as this and similar practices remain firmly optional So, what does that mean ultimately? Should I go for good shading or no "invisible" condlines? RE: "invisible" condlines for fine shading - Orion Pobursky - 2022-07-13 Whatever you feel is best. It doesn't affect the geometry, only the shading in some programs. RE: "invisible" condlines for fine shading - Max Murtazin - 2022-07-13 Thanks, got it |
