[Complete] Optimus Prime parts - Printable Version
+--- Thread: [Complete] Optimus Prime parts (/thread-26446.html)
Pages: 1 2
RE: Optimus Prime parts - George Hsia - 2022-06-23
(2022-06-23, 13:58)Gerald Lasser Wrote: Here you are, sorry for the delay
https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/1762.dat
[Image: 1762.png]
Thanks Gerald.  I imported into Part designer -> Lego Studio but seems to be having issues snapping to 2x2 plates.   Have you seen any issues?
RE: Optimus Prime parts - Gerald Lasser - 2022-06-23
(2022-06-23, 18:52)George Hsia Wrote: Thanks Gerald.  I imported into Part designer -> Lego Studio but seems to be having issues snapping to 2x2 plates.   Have you seen any issues?
Which connections did you add?
I am not using PD daily, but when I add these three bottom-connections according to these scheme in the picture it will snap to a 2x2 plate and also to a single stud between the ribs. Strange that one position is 0,41 to fit exactly.
edit: turns out nice, edit once more, correct colour now
(2022-06-23, 14:21)Magnus Forsberg Wrote: 53029 is made, and is on the Part Tracker
[Image: 53029.png]
https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/53029.dat
Thanks Magnus,
   Sorry I'm a noob at PartDesigner.   I get the following error (see attachment).
George
(2022-06-23, 20:17)Gerald Lasser Wrote: Which connections did you add?
I'm just added the connections and works great!  Thanks.
George
RE: Optimus Prime parts - Max Murtazin - 2022-07-09
(2022-06-23, 21:50)George Hsia Wrote: Thanks Magnus,
George
Yeah I'm like a month late or smth, but it is a problem you can deal with by copying the subpart you need to both [Studio install directory]\ldraw\parts\s and C:\Users\murta\AppData\Local\Stud.io\CustomParts\parts\s
Prob there is a way more convenient way to do that but I'm not aware of that
RE: Optimus Prime parts - George Hsia - 2022-07-11
(2022-07-09, 21:37)Max Murtazin Wrote: Yeah I'm like a month late or smth, but it is a problem you can deal with by copying the subpart you need to both [Studio install directory]\ldraw\parts\s and C:\Users\murta\AppData\Local\Stud.io\CustomParts\parts\s
Thanks Max, I appreciate the follow-up.   I figured it out shortly after posting my message.  I only added the subpart to the User AppData directory, but so far so good.  Thanks!
RE: Optimus Prime parts - Philippe Hurbain - 2022-07-11
(2022-07-11, 3:14)George Hsia Wrote: Thanks Max, I appreciate the follow-up.   I figured it out shortly after posting my message.  I only added the subpart to the User AppData directory, but so far so good.  Thanks!
Yes that's the way to go. Afaik the only type of files that need to be added to studio internal library is new primitives. Studio itself finds them properly in CustomParts \p folder, but parts designer needs them in internal library.
