trixBrix Switch - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: trixBrix Switch (/thread-26415.html) |
trixBrix Switch - Knud Ahrnell Albrechtsen - 2022-05-31 Hi I have for a while now moved away from original LEGO Train tracks as the turns er too narrow for my larger steam trains. Therefor i would very much like some om trixbrix parts to be made in ldraw, so i can do instructions with them. In partucular i would like their R104 switch both left and right. If possible also their ballast part that goes with the above switches. Last I would also like to have made their double crossover R104 Also here if possible including their ballast part for this crossover. Thanks RE: trixBrix Switch - Cam's Bricks - 2022-05-31 (2022-05-31, 5:51)Knud Ahrnell Albrechtsen Wrote: Hi I have not seen the TB switches up close but some detailed pics would be needed. I have also considered re-imagining how tracks are done in LDraw but I havent had time to fully realize my idea. RE: trixBrix Switch - Knud Ahrnell Albrechtsen - 2022-06-03 (2022-05-31, 12:31)Cam's Bricks Wrote: I have not seen the TB switches up close but some detailed pics would be needed. I have also considered re-imagining how tracks are done in LDraw but I havent had time to fully realize my idea. I have the R104 double crossing with the ballast, so i can send you all the pictures you need ![]() I will soon order the left R104 switch with ballast so those i can send to you also when it arrives
RE: trixBrix Switch - Knud Ahrnell Albrechtsen - 2022-06-03 I have made this motorized double corssing and would love to finish the instructions for it including the crossing and the ballast for it ![]() https://www.youtube.com/watch?v=EqCOt4UhYFI |
