Help fixing parts - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: Help fixing parts (/thread-26283.html) |
Help fixing parts - Sparky678911 - 2022-04-27 Some help please i been trying to join the sections i have circled but now doing my head in no matter what i can not get right is there a easy way or a short cut to help me starting to do my head in thank you RE: Help fixing parts - Roland Melkert - 2022-04-27 (2022-04-27, 19:07)Sparky678911 Wrote: Some help please i been trying to join the sections i have circled but now doing my head in no matter what i can not get right is there a easy way or a short cut to help me starting to do my head in thank you Seems like a though one, but it's hard to say what to do without some more visual information. If you can reduce the problem to "I need to rotate two things to get a fixed length thing in between them" you can use the selection tool as used in this tutorial: https://www.youtube.com/watch?v=qe7Jnt1uvGI But even then I suspect the problem will be the "fixed thing" itself not being on the same plane. |
