is there no shortcut to snap the frame to a part? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: is there no shortcut to snap the frame to a part? (/thread-26269.html) |
is there no shortcut to snap the frame to a part? - Richard L.P. - 2022-04-25 im using LeoCAD, i looked at the hotkey shortcuts and couldn't find the shortcut for snapping the camera (not a camera you place, but the default view you use) i couldn't find a shortcut to snap it twords a part you select. For example, on Maya Autodesk, if you click on something and press F the camera frame is snapped onto it. i was wondering if there was no alternative to that here. since it feels very tedious to have to rotate / pan / rotate / pan / rotate / pan / for 30 seconds, and do what on the other hand would take 2 or 3 seconds if you had the options to snap to a part. is there no option to snap the camera to a part in LeoCAD? or did i just overlook it? |
