shortcut to snap view piece to a piece? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: shortcut to snap view piece to a piece? (/thread-26268.html) |
shortcut to snap view piece to a piece? - Richard L.P. - 2022-04-24 is there no key shortcut to snap a piece to the center of view? for example on Maya Autodesk ,if you had something selected and pressed F, it would bring that object to the center of the frame, in other words it would bring the frame to that object where it would then be centered on it and the rotation of the camera would be orientated around it aswell. is there no shortcut for bringing the camera frame to a part? RE: shortcut to snap view piece to a piece? - Max Murtazin - 2022-04-24 (2022-04-24, 21:48)Richard L.P. Wrote: is there no key shortcut to snap a piece to the center of view?What software do you use? LDCad? LDView? LeoCAD? Studio? RE: shortcut to snap view piece to a piece? - Richard L.P. - 2022-04-24 (2022-04-24, 21:59)Max Murtazin Wrote: What software do you use? LDCad? LDView? LeoCAD? Studio? LeoCAD |
