Problem with rendering flexed part - Printable Version
+--- Thread: Problem with rendering flexed part (/thread-26261.html)
Problem with rendering flexed part - CJ H. - 2022-04-21
Hi all,
I flexed a part in LDCad which needs to be rendered in Studio. In Studio instruction maker, the part looks fine, but when I render it has gaps:
[Image: string.png?dl=1]
That's the catalog (unflexed) part on top and the flexed part on the bottom.
Maybe this is a hint: I notice something I haven't seen before in the file: the flexed part has a subfile. It says:
0 //Fixed color segments 0 //  Skin meta #1 is using a static color. 0 //  To ensure correct edge colors those segments are placed in (a) subpart(s). 1 0 0 0 0 1 0 0 0 1 0 0 0 1 stringStudsLQ-1_subPart1.ldr
Any ideas?
Thanks,
cj
RE: Problem with rendering flexed part - Roland Melkert - 2022-04-21
(2022-04-21, 16:47)CJ H. Wrote: I flexed a part in LDCad which needs to be rendered in Studio. In Studio instruction maker, the part looks fine, but when I render it has gaps:
This probably has to do with studio normalizing the scaled sections.
A workaround for this is discussed in this thread:
https://forums.ldraw.org/thread-23006.html?highlight=scale
RE: Problem with rendering flexed part - CJ H. - 2022-04-22
(2022-04-21, 17:08)Roland Melkert Wrote: This probably has to do with studio normalizing the scaled sections.
Thanks Roland. That solved the problem for me. I had referred to that thread a long time ago when I was first learning LDCad, but had completely forgotten about it.
