Help me understand - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html) +--- Thread: Help me understand (/thread-26140.html) |
Help me understand - Fredrik Hareide - 2022-03-19 I am still learning the ways of ldraw and right now I'm trying to understand the last comment on this part. Should all edges and cond lines be in s01? Is that the issue? I didn't find a way to comment on the post. So tried here instead. https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/48156.dat Thanks! RE: Help me understand - Magnus Forsberg - 2022-03-19 (2022-03-19, 11:43)Fredrik Hareide Wrote: I am still learning the ways of ldraw and right now I'm trying to understand the last comment on this part. Should all edges and cond lines be in s01? Is that the issue? I didn't find a way to comment on the post. So tried here instead. You can answer by making a review, and use the "novote" function. RE: Help me understand - Willy Tschager - 2022-03-19 (2022-03-19, 11:43)Fredrik Hareide Wrote: I am still learning the ways of ldraw and right now I'm trying to understand the last comment on this part. Should all edges and cond lines be in s01? Is that the issue? I didn't find a way to comment on the post. So tried here instead. Yes. See for example: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/s/11435s01.dat and it's subfiles. w. RE: Help me understand - Philippe Hurbain - 2022-03-20 Quoted for PT review. (2022-03-19, 15:34)Willy Tschager Wrote: All edges and conds in the patternable subfiles have to moved to s01.This may be applicable here, but in general I don't like to separate condlines from surfaces they apply to. Some simple patterns does benefit from trimming condlines to fit the pattern. This is much more complicated to do if they lie in another file! |
