Help required using LDCad - Printable Version
+--- Forum: All Other Programs. (https://forums.ldraw.org/forum-26.html)
+--- Thread: Help required using LDCad (/thread-25737.html)
Pages: 1 2
RE: Help required using LDCad - Martin Stockton - 2021-12-21
(2021-12-21, 12:18)Gerald Lasser Wrote: YOur file should be fine, looks like LDCad cannot locate the parts.
How do your search path look like?
Prefs -> LDraw -> Search (library) paths
Are there proper directories with parts behind them?
Hi Gerald, I found a folder that said 'complete' so I opened that and it has put all the parts back on!! phew!!!!! If I now use LDCad if I have loaded some new items on where will I find them?
Regards Martin. Smile
RE: Help required using LDCad - Martin Stockton - 2021-12-23
RE: Help required using LDCad - Martin Stockton - 2021-12-29
(2021-12-23, 17:37)Martin Stockton Wrote: Hi Gerald, I found a folder that said 'complete' so I opened that and it has put all the parts back on!! phew!!!!! If I now use LDCad if I have loaded some new items on where will I find them?
Hi Gerald, thank you so much for your help, it has really sorted me out. My daughter was here the other day and has helped me to load the extra parts so all is good. Hope you had a good christmas and all the best for the new year!
Regards Martin.
RE: Help required using LDCad - Orion Pobursky - 2021-12-29
I made a short tutorial (with pictures!) in case you get lost doing this again
https://wiki.ldraw.org/wiki/How_to_Add_Unofficial_Parts_in_LDCad
RE: Help required using LDCad - Martin Stockton - 2021-12-30
(2021-12-29, 18:54)Orion Pobursky Wrote: I made a short tutorial (with pictures!) in case you get lost doing this again
That's mega. I have printed it off for future reference.
Thanks Again Martin.
