Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat (/thread-24927.html) |
Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - KristyB - 2021-08-22 I'm trying to build a library of game-ready parts for use in video games, and would like a library of low-poly bricks to fall back on for bricks I have not yet converted by hand. I've dug around and tried a few methods so far, but all have failed to work. LdrDat2Obj: Processes 1,466 dats out of the 14,038 in ldraw's parts directory, and then exits silently with no error or log. the last brick it appears to process is 22385p050.dat It processes the parts in an order I can't decipher, so skipping this last brick and moving on isn't possible. LdrDat2Obj2: no apparent batch process Toby Nelson/TobyLobster's blender importer: seems to work well, but only allows one .dat to import at a time - that's not workable with 14,000 parts. Matthew Morrison's blender importer: Crashes every time I try to import a .dat file. I posted more details about the crash in his thread: https://forums.ldraw.org/thread-24153.html LDView: no apparent batch process Stud.IO: no way I can see to create a file that contains each brick once. If I could get the ldraw parts into any conventional 3D model format I would be able to batch convert the results into something game engines can use, including obj, fbx, stl, dae, and -probably- usd. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Gerald Lasser - 2021-08-22 What about using LDView on the command line and build a batch processing aroudn it? RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Travis Cobbs - 2021-08-22 (2021-08-22, 12:45)KristyB Wrote: LDView: no apparent batch process LDView itself does not support globbing (*.dat, for example), but it can be called from a batch file that does. It supports command line exports to POV, STL (monochrome output), and 3DS. Please search for ExportFiles, SaveExportType, and ExportSuffix in LDView's help file for instructions on using it. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - KristyB - 2021-08-23 (2021-08-22, 21:39)Travis Cobbs Wrote: LDView itself does not support globbing (*.dat, for example), but it can be called from a batch file that does. It supports command line exports to POV, STL (monochrome output), and 3DS. Please search for ExportFiles, SaveExportType, and ExportSuffix in LDView's help file for instructions on using it.Thank you both for the suggestion! Iterating through a list that both skips numbers and has arbitrary letters sprinkled in with the numbers seems a bit daunting, and my experience with bats file is less than rudimentary. I'm also not sure what globbing is in this context. It might take me a good while, so if anyone has other suggestions while I tinker with it I'd be glad to hear them too. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - KristyB - 2021-08-26 It occurs to me I can also use Python in in blender to script the import/export process, maybe? I'm already pretty familiar with Python, and Toby Nelson's .dat import options would allow me to automate the high-poly making process for a lot of the Bricks. I am going to try this route first before looking at LDView. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Gerald Lasser - 2021-08-26 (2021-08-23, 11:22)KristyB Wrote: Thank you both for the suggestion! A simple batch file like Code: for %%f in (*.dat) do call ldview....Should do. Please note, I did not try this and you would need to specify the filename (especially the ecport name) also in the ldview command string. Add an 'echo'to see the progress RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Matthew Morrison - 2021-09-04 (2021-08-22, 12:45)KristyB Wrote: I'm trying to build a library of game-ready parts for use in video games, and would like a library of low-poly bricks to fall back on for bricks I have not yet converted by hand. I've dug around and tried a few methods so far, but all have failed to work. Are you still getting the crash? I've pushed a few updates since you posted the error report. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Kuemmerle - 2023-06-23 i got it to work with this: @echo off set sourcedir=F:\ldview iter test\parts set exportdir=F:\ldview iter test\stlexp for %%f in ("%sourcedir%\*.dat") do ( "E:\LEGO\LDraw suite\LDView\LDView64.exe" -ExportFile="%exportdir%\%%~nf.stl" "%%f" ) but for some reason its exporting parts super small RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Travis Cobbs - 2023-06-23 (2023-06-23, 5:34)Kuemmerle Wrote: i got it to work with this: Try doing an STL export from the LDView UI, then go to the export options and check the units. Choose and appropriate unit and export to verify. The command line should use the most recently selected units from LDView UI. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Kuemmerle - 2023-06-24 (2023-06-23, 17:13)Travis Cobbs Wrote: Try doing an STL export from the LDView UI, then go to the export options and check the units. Choose and appropriate unit and export to verify. The command line should use the most recently selected units from LDView UI. That worked, thanks so much. RE: Help converting -all- .dat parts to fbx/obj/stl/usd/anyConventionalFileFormat - Kuemmerle - 2023-06-24 after making that, i also made this python script to rename everything if u want: Code: import osThis just reads the metadata in the.dat files before converting to stl and appends it to the file name |
