About the display of the LEGO logo on Brick studs - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: About the display of the LEGO logo on Brick studs (/thread-24871.html) |
About the display of the LEGO logo on Brick studs - Yamamoto - 2021-08-14 I'm a non-English speaking person, so I may not be able to speak well. I'll do my best. I'm going to use LDraw to create an animation and upload it to YouTube. In this case, should I hide the LEGO logo on the brick studs? RE: About the display of the LEGO logo on Brick studs - Jaco van der Molen - 2021-09-14 (2021-08-14, 6:56)Yamamoto Wrote: I'm a non-English speaking person, so I may not be able to speak well. Hi Yamamoto, Your English is fine ;-) If you do not remove it, rendering all the frames for your animation will take longer. Depending on the level of detail you want I'd say remove it to decrease rendering time. RE: About the display of the LEGO logo on Brick studs - Yamamoto - 2022-06-07 (2021-09-14, 12:30)Jaco van der Molen Wrote: Hi Yamamoto, Thank you for coming back to me. I apologize for the late reply. Will there be legal issues with displaying the logo? RE: About the display of the LEGO logo on Brick studs - Willy Tschager - 2022-06-07 (2022-06-07, 2:30)Yamamoto Wrote: Thank you for coming back to me. As far as I know 'til today nobody was concerned to remove the logo from all the parts used in real life brickfilms. You would do it just because you can do it with a click? w. RE: About the display of the LEGO logo on Brick studs - Yamamoto - 2022-06-10 (2022-06-07, 7:08)Willy Tschager Wrote: As far as I know 'til today nobody was concerned to remove the logo from all the parts used in real life brickfilms. You would do it just because you can do it with a click? Thank you for your reply. I was too worried. I'm planning to display the logo. |
