Text size variation in forum posts - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Administrative (https://forums.ldraw.org/forum-4.html) +--- Forum: Website Suggestions/Requests/Discussion (https://forums.ldraw.org/forum-23.html) +--- Thread: Text size variation in forum posts (/thread-24498.html) |
Text size variation in forum posts - Philippe Hurbain - 2021-03-16 When I copy/paste text in forum, this text is rendered slightly smaller than "normal text" This is normal text This is normal text copy/pasted This is normal text copy/pasted then format removed This is normal text set in size 3 (same size as pasted text) This is normal text set in size 4 (bigger than normal text) RE: Text size variation in forum posts - Orion Pobursky - 2021-03-16 (2021-03-16, 15:21)Philippe Hurbain Wrote: When I copy/paste text in forum, this text is rendered slightly smaller than "normal text" I'm aware of this "feature". Right now there are two ways to prevent this: - Ctrl-Shift-V to paste if you have a keyboard - Switch to plain text mode (the last button on the toolbar next to the 4 green arrows) and then paste. I'll do a quick search of the options to see if this is easily disableable. RE: Text size variation in forum posts - Orion Pobursky - 2021-03-16 (2021-03-16, 16:50)Orion Pobursky Wrote: I'll do a quick search of the options to see if this is easily disableable. It was easily disableable. I downloaded the plugin, changed the template to load it, and viola pasted text is no longer formatted. RE: Text size variation in forum posts - Philippe Hurbain - 2021-03-16 (2021-03-16, 17:30)Orion Pobursky Wrote: It was easily disableable. I downloaded the plugin, changed the template to load it, and viola pasted text is no longer formatted. Thanks Orion! RE: Text size variation in forum posts - Travis Cobbs - 2021-03-16 (2021-03-16, 17:30)Orion Pobursky Wrote: It was easily disableable. I downloaded the plugin, changed the template to load it, and viola pasted text is no longer formatted. Having pasted text be formatted was actually useful, although the fact that it got misinterpreted wasn't good. I guess not formatting it at all is probably better than always formatting it wrong. |
