LDraw.org 2020-03 Parts Update Now Available - Printable Version
+--- Forum: LDraw.org Announcements (https://forums.ldraw.org/forum-1.html)
+--- Thread: LDraw.org 2020-03 Parts Update Now Available (/thread-24356.html)
Pages: 1 2 3 4 5
RE: LDraw.org 2020-03 Parts Update Now Available - Chris Dee - 2021-01-16
(2021-01-08, 22:35)Chris Dee Wrote: We should use only 'Grey' - the Australian English spelling . These were overlooked by all reviewers, including me. I should add a check to the update build process and recycle those using 'Gray'.
All updated and fast-tracked. I also fixed the few occurrences of LtGrey and DkGrey.
RE: LDraw.org 2020-03 Parts Update Now Available - Willy Tschager - 2021-01-16
(2021-01-16, 10:04)Chris Dee Wrote: All updated and fast-tracked. I also fixed the few occurrences of LtGrey and DkGrey.
Heart w.
RE: LDraw.org 2020-03 Parts Update Now Available - Travis Cobbs - 2021-02-04
While generating the PDF part catalog for this release, I discovered that part 35860.dat has a !CATEGORY of Minifir Accessory. I'm editing my local copy and regenerating the catalog to avoid having that category in the catalog.
RE: LDraw.org 2020-03 Parts Update Now Available - Jaco van der Molen - 2021-02-04
(2021-02-04, 7:13)Travis Cobbs Wrote: While generating the PDF part catalog for this release, I discovered that part 35860.dat has a !CATEGORY of Minifir Accessory. I'm editing my local copy and regenerating the catalog to avoid having that category in the catalog.
Travis, do you post that PDF part catalog somewhere?
RE: LDraw.org 2020-03 Parts Update Now Available - Chris Dee - 2021-02-04
Fixed and fast-tracked for inclusion in the next update.
RE: LDraw.org 2020-03 Parts Update Now Available - Willy Tschager - 2021-02-04
(2021-02-04, 11:48)Jaco van der Molen Wrote: Travis, do you post that PDF part catalog somewhere?
The catalog gets updated on my request and is part of the AIOI.
(2021-02-04, 17:31)Willy Tschager Wrote: The catalog gets updated on my request and is part of the AIOI.
Right now, I only generate this for Willy to put into the AIOI. I use a custom bash shell script that I created myself that runs on my Mac. The script generates HTML, which I then import into a master document in LibreOffice, and then export from there to PDF.
Safari, Chrome, and Firefox all have serious issues with table pagination that prevents me from simply printing to PDF from a web browser. (I just verified that again today.)
As an aside, the 2020-03 PDF is 79 MB. My script actually has support for high-DPI (200%) scaling of all the images, but I don't use that. I'm not entirely sure that scaling still works, but the generated PDF would likely be about four times bigger with that enabled.
RE: LDraw.org 2020-03 Parts Update Now Available - Jaco van der Molen - 2021-02-05
Ah yes. Since I do not use the AIOI, could it be hosted somewhere to download?
RE: LDraw.org 2020-03 Parts Update Now Available - sunil808 - 2021-05-20
If I check 2400.dat in the complete.zip it has a bad file ending, but the corrected/updated version is OK.
