[LDCad] Kinematics in LDCad - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: [LDCad] Kinematics in LDCad (/thread-24353.html) |
Kinematics in LDCad - Johann Eisner - 2020-12-29 Hi guys I was asked a question that I couldn't answer 100 percent. As far as I know, it doesn't work. Here's the question: Hi Johann. Is there a possibility to move the kinematics in the LDcad? Example: I have a rectangle built from individual parts and want to move it to a parallelogram by twisting an arm around its pin at one of the joints. In the LDD, if you built the joints according to a certain scheme, then the movement of the remaining parts ran smoothly. Johann RE: Kinematics in LDCad - Orion Pobursky - 2020-12-30 The only editor to actually do this was SR3DBuilder. LDCad does not support the ability to move connected objects. RE: Kinematics in LDCad - Johann Eisner - 2020-12-30 (2020-12-30, 0:13)Orion Pobursky Wrote: The only editor to actually do this was SR3DBuilder. LDCad does not support the ability to move connected objects. Hi Orion That is / was my level of knowledge. Thank you for the confirmation. Johann RE: Kinematics in LDCad - Roland Melkert - 2020-12-30 (2020-12-29, 9:21)Johann Eisner Wrote: Hi Johann. Is there a possibility to move the kinematics in the LDcad? Example: I have a rectangle built from individual parts and want to move it to a parallelogram by twisting an arm around its pin at one of the joints. In the LDD, if you built the joints according to a certain scheme, then the movement of the remaining parts ran smoothly. As Orion wrote this isn't supported in the editor of LDCad. But you can animate it if you want, by writing a lua script. And in the upcoming 1.7 interactive animations will become possible. So if you need it for some mechanics demonstration or something that could be an alternative. RE: Kinematics in LDCad - Johann Eisner - 2020-12-30 (2020-12-30, 20:40)Roland Melkert Wrote: As Orion wrote this isn't supported in the editor of LDCad.Hi Roland Thanks for the answer. My friend is less concerned with animation. He just wants to test certain flexible connections to see if the model can be built that way. I'm looking forward to the 1.7 or maybe the 2.0 version. Is there already a time horizon? RE: Kinematics in LDCad - N. W. Perry - 2020-12-31 (2020-12-30, 21:15)Johann Eisner Wrote: Hi Roland Although LDCad can't (yet) do this interactively, it's pretty easy to calculate certain rotations using the Selection Info feature, especially for something simple like a parallelogram. I've also used rubber band templates to "draw" circles of a known radius in my model, showing for example the rotations of different parts to see where, and if, they intersect. (I've always thought it would be handy if Selection Info could display these circles automatically, and compute their intersections, like it can already do with triangles. But you could probably create a script to do that, too.) |
