[Complete] Minifig Torso 973pb1849 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: [Complete] Minifig Torso 973pb1849 (/thread-24327.html) |
Minifig Torso 973pb1849 - Manfred Schaefer - 2020-12-16 Hello, I need this minfig torso 973pb1849
https://www.bricklink.com/v2/catalog/catalogitem.page?P=973pb1849&name=Torso%20Female%20Shirt%20with%202%20Pockets,%20Tan%20Scarf%20and%20Black%20Belt%20with%20Gold%20Buckle%20Pattern&category=%5BMinifigure,%20Torso%5D#T=C&C=69 Can someone do this for me? Thanks in advance. Regards Manfred RE: Minifig Torso 973pb1849 - Takeshi Takahashi - 2021-02-17 I'll take this part. Part number is 973pcd6 (Collectible minifigures (numbered series) - Series 13, No.6) Please wait for a while to create the print pattern. RE: Minifig Torso 973pb1849 - Takeshi Takahashi - 2021-02-18 Done!! https://www.ldraw.org/cgi-bin/ptdetail.c...73pcd6.dat If you (or other member) find any errors, I'll correct them. RE: Minifig Torso 973pb1849 - Manfred Schaefer - 2021-02-22 (2021-02-18, 8:38)Takeshi Takahashi Wrote: Done!!Many Thanks. Good work. ![]() I'll check it out and give feedback here. Greetings Manfred RE: Minifig Torso 973pb1849 - Manfred Schaefer - 2021-03-04 (2021-02-18, 8:38)Takeshi Takahashi Wrote: Done!! Hello, I mean the colors are not quite right. I changed the colours in my copy and attached it below. The numbers in the picture are the LDraw colors which I think are correct. Greeting Manfred RE: Minifig Torso 973pb1849 - Orion Pobursky - 2021-03-04 I think what you have labeled as 226 should be 14. The slight darkening of the yellow is due to the dark tan base plastic and yellow is the color of minifig "flesh" RE: Minifig Torso 973pb1849 - Philippe Hurbain - 2021-03-05 (2021-03-04, 22:13)Orion Pobursky Wrote: I think what you have labeled as 226 should be 14. The slight darkening of the yellow is due to the dark tan base plastic and yellow is the color of minifig "flesh" I think that the colors chosen by Takeshi are right (including the dark grey of shirt shadows). Bleed through of plastic dark tan color can be misleading! It's more questionable for buckle color, but I think that plain yellow is right: if you look at this video https://youtu.be/CGvi6zpKRD4?t=248 you see no light reflection that metallic ink would show at some angles. RE: Minifig Torso 973pb1849 - Vincent Messenet - 2021-03-05 (2021-03-05, 9:03)Philippe Hurbain Wrote: I think that the colors chosen by Takeshi are right (including the dark grey of shirt shadows). Bleed through of plastic dark tan color can be misleading! It's more questionable for buckle color, but I think that plain yellow is right: if you look at this video https://youtu.be/CGvi6zpKRD4?t=248 you see no light reflection that metallic ink would show at some angles. IMHO the belt buckle is Metallic Gold. The video shows there is a change of the yellow ink with a slight light reflection according to some angles RE: Minifig Torso 973pb1849 - Magnus Forsberg - 2021-03-05 I have this figure. The colours are Black, DBGrey, Tan, Yellow and Metallic gold. RE: Minifig Torso 973pb1849 - Manfred Schaefer - 2021-03-06 (2021-03-05, 15:43)Magnus Forsberg Wrote: I have this figure. Hello, I also have this minifig body. To check the colours, I have used tiles. Okay, there some points, which can have influence. The light of the environment, the colour on the screen. If this part will be an official part with this colours, it is no problem for me. I am happy that this part ist realized and many thank to the part author. Greeting Manfred |
