59233 - Minifig Lightning - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: 59233 - Minifig Lightning (/thread-24224.html) |
59233 - Minifig Lightning - Evert-Jan Boer - 2020-10-01 I created a revision of part 59233, left the current official part, right my new part: Before I finish this part, what about the roundings? I used sharp angles because I thought it looked better and was easier to model. I want to round the ends a bit, but what about the other angles, should they all be rounded? RE: 59233 - Minifig Lightning - Magnus Forsberg - 2020-10-01 There seems to be 2 versions of this part. https://brickset.com/parts/design-59233 We should make 59233a and 59233b Could it be that the original ldd data was wrong? Are you also creating subfiles for the dual mould? RE: 59233 - Minifig Lightning - Evert-Jan Boer - 2020-10-01 (2020-10-01, 16:15)Magnus Forsberg Wrote: There seems to be 2 versions of this part. I think the original LDD data was wrong. When looking at the pictures of the sets containing the part they all seem to use the same design. The parts I have come from 10188, one of the early releases, it is element ID 6321092. I did take into account the dual color option, but did not yet subpart the second color. RE: 59233 - Minifig Lightning - Philippe Hurbain - 2020-10-01 (2020-10-01, 15:00)Evert-Jan Boer Wrote: I want to round the ends a bit, but what about the other angles, should they all be rounded?IMHO with rounded ends it will be fine! RE: 59233 - Minifig Lightning - Magnus Forsberg - 2020-10-01 (2020-10-01, 18:48)Philippe Hurbain Wrote: IMHO with rounded ends it will be fine! Yes, keep the rounded corners. RE: 59233 - Minifig Lightning - Philippe Hurbain - 2020-10-02 (2020-10-01, 21:15)Magnus Forsberg Wrote: Yes, keep the rounded corners. I meant rounded ends, not corners. I'm fine with sharp spikes. |
