[LPub3D] Change multi step assem margins to ignore callouts? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: [LPub3D] Change multi step assem margins to ignore callouts? (/thread-24193.html) |
[LPub3D] Change multi step assem margins to ignore callouts? - Cam's Bricks - 2020-09-04 Is this even possible? Right now if I create a multi step page and one of the steps has a callout, that callout is counted as the step's total area for the purposes of margin calculation. This is an issue if I want to make a second column. Maybe there is a way to have the default callout position, and therefore margin calculation, to be under the step image instead of to the right? Then I could used the 0 !LPUB RESERVE and/or margin parameters to better shape the way the page is laid out. Thanks, Cameron PS has anyone heard from Trevor? I have emailed a couple times and havent seen him respond on sourceforge in months. The last login here was also in early march. |
