Parts in LDCad - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: Parts in LDCad (/thread-24177.html) |
RE: Parts in LDCad - Sparky678911 - 2020-12-21 ok so how can i sort this please RE: Parts in LDCad - N. W. Perry - 2020-12-21 (2020-12-20, 22:02)Sparky678911 Wrote: Hi great thanks for help i got that part now sort one question when i close the program it is asking me to save that part what and where do i save it to or do i not have to save thanks If you chose the option to "create a new loose file" when adding the (flexible?) part to your model, then you will have to save it separately when you exit the program. You can save it anywhere you like, but be sure it's somewhere that's in LDCad's search paths if you plan to use it again. RE: Parts in LDCad - N. W. Perry - 2020-12-21 (2020-12-21, 13:26)Sparky678911 Wrote: ok so how can i sort this please What steps did you take to "download the parts" for 67141? Did you take just the individual files for this part, or did you get an updated copy of the full unofficial library? If MLCad can find it, it must have been saved somewhere on your computer other than in the unofficial library zip file. Try a file search for 67141.dat and see if you can find where it is. RE: Parts in LDCad - Sparky678911 - 2020-12-21 (2020-12-21, 16:13)N. W. Perry Wrote: What steps did you take to "download the parts" for 67141? Did you take just the individual files for this part, or did you get an updated copy of the full unofficial library? i downloaded individual files for the part i just searched my PC results below RE: Parts in LDCad - Roland Melkert - 2020-12-21 (2020-12-21, 22:15)Sparky678911 Wrote: i downloaded individual files for the part i just searched my PC results below MLCad uses unofficial content from a subfolder in the official content, this is not supported by LDCad as it interferes with the zipped library usagae. This because LDCad considers a library a self contained thing, but in you can have as multiple libraries installed at once. So even if you need parts from a non ldraw source just place them in a new /parts /p structure and register that location as additional library. And if it's an official 'unofficial' LDraw part just update your ldrawunf.zip (which you are already using in LDCad) to the latest version and restart the program. RE: Parts in LDCad - Sparky678911 - 2020-12-24 (2020-12-21, 22:54)Roland Melkert Wrote: MLCad uses unofficial content from a subfolder in the official content, this is not supported by LDCad as it interferes with the zipped library usagae. Cool thanks i got it now one more thing on the same thing now i have made my flex axle is the image below right it adds a line for everyone i do thanks RE: Parts in LDCad - ferra - 2022-04-25 Sorry to ask, but has anyone here had any issues with MLCad using unofficial content? I'm having some weird hard drive issue and I'm trying to figure out if it's possible due to some software incompatibility. For example, if I use two different applications at the same time with their standalone libraries. Or maybe it's a contradiction between official or unofficial components. I have already agreed with a specialist that I will take the hard drive to service for damage analysis, but I would like to try to figure it out on my own first. Edit: Extrnal URL removed, irrelevant RE: Parts in LDCad - Gerald Lasser - 2022-04-25 (2022-04-25, 12:05)ferra Wrote: Sorry to ask, but has anyone here had any issues with MLCad using unofficial content? I'm having some weird hard drive issue and I'm trying to figure out if it's possible due to some software incompatibility. For example, if I use two different applications at the same time with their standalone libraries. Or maybe it's a contradiction between official or unofficial components. I have already agreed with a specialist that I will take the hard drive to service for damage analysis, but I would like to try to figure it out on my own first. No issue with MLCAD and Unoffical Lib, adde the corresponding path to MLCAD. Better use LDcad, a much modern solution |
